Why Can't I See Stylus RMX or Sampletank in DP5?
johnnyvince
Post by johnnyvince »
When I create an instrument track and then select a MOTU V.I. from insert #1, I see that instrument's GUI. If I then switch it via the dropdown menu to SampleTank or Stylus RMX, it does switch over, but I don't get a GUI. Neither is either V.I. available as a MIDI track destination. I re-installed the latest version of Stylus RMX, with no change. Both plug-ins have been working fine in ProTools. Am I missing something? I'm fluent in Macs and ProTools, but not in DP (yet)...so maybe it's something really obvious.
Thanks.
MacMini Server 2GHz Intel Core i7/ 4GB RAM / OS 10.7.5 / FireFace800 / MTP AV-USB / DP 8.01 / Reason 6.5.2 / Live 8.3.4 / Waves 9.1
chrispick
Post by chrispick »
If your VI is loaded correctly, you should be able to double-click on its name in the insert area on the Mixer Window at any time and the VI's interface will pop up. You can also double-click on its name in the Track Overview to do the same.
Once you've loaded a VI properly, you can select a different VI via the Mixer Window's insert. It should bring up the new VI. If the VI interface doesn't pop up, you should be able to double-click like stated above to see it.
johnnyvince
Thanks, chrispick. Yeah, when I double-click on Stylus or Sampletank on the insert, it does pop up, but only as a minimized window (I see DP's drop-down selectors and window controls, but no plug-in GUI). Yet, if I double click a MOTU V.I., then it pops up as you'd expect, GUI and all... I thought maybe there was some preference I'd missed or something. Since most everyone else seems to be generally happy with them, I've decided that DP just hates me personally. :roll:
chrispick
Post by chrispick »
johnnyvince wrote:Thanks, chrispick. Yeah, when I double-click on Stylus or Sampletank on the insert, it does pop up, but only as a minimized window (I see DP's drop-down selectors and window controls, but no plug-in GUI). Yet, if I double click a MOTU V.I., then it pops up as you'd expect, GUI and all... I thought maybe there was some preference I'd missed or something. Since most everyone else seems to be generally happy with them, I've decided that DP just hates me personally. :roll:
That may mean your VI isn't routed to an active output channel. Or your audio interface isn't turned on (unlikely, I know, but I present it as an option). Did you check these things?
johnnyvince
chrispick wrote:That may mean your VI isn't routed to an active output channel. Or your audio interface isn't turned on (unlikely, I know, but I present it as an option). Did you check these things?
Ermmm, yeah...well, now that you mention it, the output was set to the default "built-in 1-2". :oops: Stylus works like a charm now. :roll:
Now DP quits whenever I try to assign Sampletank to the 002's outputs 1+2, but I seem to remember some documentation about that somewhere. Thanks for the help, chrispick!
