Motu UltraLite OUTPUTS
I have my main monitors using the LEFT/RIGHT then i have LOGITECH 5.1 hooked up to the other outputs. How can i change it so i have both my mainouts and the outputs put out sound?
I don't have an Ultralite, but I don't believe you can set up outputs just within the device. As far as I know, you'll have to tell your recording/playback software what tracks need to be sent to which outputs.
Again, we need to know what equipment you are using, and what you intend to use it for, in order for us to be of any real help to you. I can't tell if I'm leading you in the right direction if I don't have a clear idea of what your setup is and what you want to achieve.
Let me know and I'll do my best to help.
Okay after another day of fooling around.
Still alittle strong on one side but good for now. Got both speakers working. Had to route 1-3 first then did mains. works perfect. Just have to figure out how to control volume for both sets of speakers. 1-3 have high volume levels.
As for my setup. PowerMac G5 Dualcore 2GHz, 4.5GB of memory, 160GB SATA and of course the MOTU Ultralite.
Anyone else find the ultralite menu (on the card) very confusing and hard to use? [/i]
