I have an issue with Audio Patch Thru. When set to Auto or Input Only, the signal is still audible when the record button is off and when the input monitor is off as well. I have to toggle the record button on and off again to get the signal to mute.
Has anyone experienced this?
Please report back *more*, DP 5 users...
This 'new input monitoring cheme' was exactly
what I was looking at to upgrade...
I'm holding back because of other reported issues,
but if the 'new input monitoring cheme' isn't working anyway, I can concentrate on other things than upgrading to DP 5
There is definitely something up but I would not let it hold you back from upgrading. There are some issues that need to be addressed but nothing that has kept me from working in a professional environment.
OortNYC wrote:There is definitely something up but I would not let it hold you back from upgrading. There are some issues that need to be addressed but nothing that has kept me from working in a professional environment.
YMMV...
I need exact reports , not 'something...'
other 'professionals' report please about the
'new input monitoring scheme'
david6101 wrote:I also have the bug of it not working properly unless I switch input monitoring off and on...then seems to work ok. Dual 2GHz G5, 1G RAM, DP5.01
