Input Monitoring Issue (Bug??)
OortNYC
Post by OortNYC »
I have an issue with Audio Patch Thru. When set to Auto or Input Only, the signal is still audible when the record button is off and when the input monitor is off as well. I have to toggle the record button on and off again to get the signal to mute.
Has anyone experienced this?
Thanks -
D -
Timeline
Post by Timeline »
You could be hearing core through PCI audio console.. I forget to check that sometime.
OortNYC
Post by OortNYC »
I don't think so. If I toggle it once on an off it goes back to normal.
Thanks for the help.
D -
pencilina
Post by pencilina »
I have the same problem. 424/2408mk1 dp5 dual1.8g5 10.3.9
Klaus
Post by Klaus »
Please report back *more*, DP 5 users...
This 'new input monitoring cheme' was exactly
what I was looking at to upgrade...
I'm holding back because of other reported issues,
but if the 'new input monitoring cheme' isn't working anyway, I can concentrate on other things than upgrading to DP 5 :cry:
Klaus
OortNYC
Post by OortNYC »
There is definitely something up but I would not let it hold you back from upgrading. There are some issues that need to be addressed but nothing that has kept me from working in a professional environment.
Klaus
Post by Klaus »
OortNYC wrote:There is definitely something up but I would not let it hold you back from upgrading. There are some issues that need to be addressed but nothing that has kept me from working in a professional environment.
YMMV...
I need exact reports ;-), not 'something...'
other 'professionals' report please about the
'new input monitoring scheme'
Best
Klaus
:roll:
Timeline
Post by Timeline »
Klaus,
Where did he say it was DP 5 he was talking about?
I see no profile either
OortNYC
Post by OortNYC »
Sorry - Yes it is DP5.01.
Klaus
Post by Klaus »
Timeline wrote:Klaus,
If you have a previous version of DP that has an input monitor switch, please send it to me, I'll take care of the licencing :lol:
No offense intended...
Take care
Klaus
Timeline
Post by Timeline »
Was referring to the original post Klaus.
Klaus
Post by Klaus »
Yes, me too ;-)
Klaus
david6101
Post by david6101 »
I also have the bug of it not working properly unless I switch input monitoring off and on...then seems to work ok. Dual 2GHz G5, 1G RAM, DP5.01
Klaus
Post by Klaus »
david6101 wrote:I also have the bug of it not working properly unless I switch input monitoring off and on...then seems to work ok. Dual 2GHz G5, 1G RAM, DP5.01
Thanks David
and best regards
Klaus
porieux
Post by porieux »
Actually, he doesn't mention an input monitor switch at all.
Guess you managed to guess correctly though :lol:
