loading existing .mid files?
travisbrown
Post by travisbrown »
Umm.. how come I can't seem to load a .mid file in DP5? Can't drag and drop, can't load from any menus... doesn't matter if it is an existing session or not.
What's the trick?
Grigri
Post by Grigri »
Hello.
Try to drag the .mid file in the chunk window, that should work.
Grigri
Digital Performer 11.31 - Mac OS Sonoma 14.6.1
travisbrown
Tried that. Nothing. File just springs back into the finder window. This is crazy. Tried it with a few different .mid files.
waxman
Post by waxman »
select info on file... to do that select file and hit "apple I"
In the dialog open with change to...
open iwith DP...
double click on icon and it will open in a DP file...
then save the file before you start to work on it...
waxman
agillesp
Post by agillesp »
I just had the same thing earlier today. What worked for me was making sure there were enough adjacent MIDI tracks in the tracks window... once there were, I was able to drag the .mid directly into the tracks window.
Hope that helps,
Art
toodamnhip
Post by toodamnhip »
agillesp wrote:I just had the same thing earlier today. What worked for me was making sure there were enough adjacent MIDI tracks in the tracks window... once there were, I was able to drag the .mid directly into the tracks window.
Hope that helps,
Art
what is a .mid file?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
travisbrown
Toodamnhip: .mid is a MIDI data file. Could be a song or other tune of MIDI sequence.
travisbrown
Waxman, that doesn't work. DP starts up, but doesn't load the file. Doesn't err out, just starts DP. I'd already tried this by ctrl clicking and opening with DP. Neither method works.
I know the .mid is okay; I can open with every other MIDI app. Tried other .mid files too.
travisbrown
By all rights I should be able to just drag the file to the tracks window and create a new track.
waxman
Post by waxman »
I don't know why that is not working on your set up. I just did it and it works fine...
dragging works if you have enough MIDI tracks
waxman
travisbrown
I dunno. I can't get any MIDI file loaded any way. Same in DP 4.6. It's a single part MIDI file. I think all I'd need is one track; but I even tried it with a new 32 track session.
I can load it in Sibelius fine.
Grigri
Post by Grigri »
Travisbrown.
I've send you my email addresse (PM) , check your message.
Can you send me one of this MIDI files so I can try on my system?
Grigri
Matcher
Post by Matcher »
You might try renaming it to .MIDI
doodles
Post by doodles »
have you tried loading it into a chunk, rather than dragging it - this might show if there's something wrong with the file??
buzzsmith
Post by buzzsmith »
Travis:
With DP running, no project open, have you tried the "Open" command to see if you can just open the MIDI file as opposed to importing it?
If successful, you'll be presented a window, where you have to reassign the different channels to match your set-up.
Just a quick thought!
=bz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
