loading existing .mid files?
Umm.. how come I can't seem to load a .mid file in DP5? Can't drag and drop, can't load from any menus... doesn't matter if it is an existing session or not.
What's the trick?
What's the trick?
select info on file... to do that select file and hit "apple I"
In the dialog open with change to...
open iwith DP...
double click on icon and it will open in a DP file...
then save the file before you start to work on it...
open iwith DP...
waxman
- toodamnhip
what is a .mid file?agillesp wrote:I just had the same thing earlier today. What worked for me was making sure there were enough adjacent MIDI tracks in the tracks window... once there were, I was able to drag the .mid directly into the tracks window.
Hope that helps,
Art
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
I don't know why that is not working on your set up. I just did it and it works fine...
dragging works if you have enough MIDI tracks
waxman
- buzzsmith
Travis:
With DP running, no project open, have you tried the "Open" command to see if you can just open the MIDI file as opposed to importing it?
If successful, you'll be presented a window, where you have to reassign the different channels to match your set-up.
Just a quick thought!
=bz=
=bz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
