trying to convert quantum leap brass Roland with UVIX
saxmonster
Post by saxmonster »
When I get home i will have to try this. I do get the two cds on my desktop the one audio cd with one track on it and the the sample cd with a number under it. how should i go about copying the sample cd to the HD? do I just copy the folders in it or make an image file of it on the HD?
I hope this will work with cdxtract.
I'll let you know how it goes.
mac with tiger 4.2
-Scott
bhagert
Post by bhagert »
I just alt-dragged it to the hard drive.
I hope that it will work ok. I just looked at some instruments in MachFive and they sounded perfectly all right.
Dual 2.0 G5/3.5GB, 10.4.6, DP 5.0, 828mkii
saxmonster
Using cdxtract I copied the one sample cd with then numbers as a name (not the audio cd part) to a HD and converted the whole cd 1 and it worked perfectly. onto the others now.
Thanks for the hint.
but why does it work this way and not the other way right out of the cd-rom.
-Scott
bhagert
Post by bhagert »
The bogus audio CD immage could not be ejected by itself so I thought that it was the one messing things up. Anyway we have a work around.
williemyers
Post by williemyers »
azusa749a wrote: Last week I tried to convert the Brass CD ROM and it didn't work.
So I e-mailed soundsonline.com twice, and haven't got the answer yet.
All I got was an e-mail from the webmaster, Jennifer Collado;
Code: Select all
Thank you for contacting us.
Your email has been forwarded to our Technical Supoort Team.
They will try to answer your email as quickly as possible.
I guess UVIX have a problem with the digital watermarks that are on the discs. (This is just my guess.)
The other Roland format disc (the strings) doesn't have it.
Again sorry about that. I'm still out for $19.95 too. I should have bought the other format instead. :(
please let us know what you hear (when you hear). I, like you, had no problem UVIX-ing the strings CD, but I, like you and others, get nothing at all with UVIX when I put in a Brass CD.
thanks
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
billf
Post by billf »
Code: Select all
thanks
What format of the Brass title did you get? The Kurzweil formatted one works fine in UViX despite the digital watermarks.
Is it possible you guys got a defective batch of disks? :?: :?:
williemyers
hey Bill,
all the discs I got were Roland. I had no trouble UVIX-ing the Ultimate Strings, but the Brass were a no go.
~me
mongoose
Post by mongoose »
billf wrote: Is it possible you guys got a defective batch of disks? :?: :?:
I'm thinking no, since I was eventually able to read the disc at a guy's studio that has a PC copy of Translator. The Roland QL Brass are just super-crabby with conversion software for some reason, it looks like.
Note that the workaround bhagert and others are talking about is does *not* work for this disc AFAIK, but for the S5000 format. With the Roland one you never get a cd volume appearing on the desktop.
-m
azusa749a
Post by azusa749a »
After 4 emails, finally they sent me a new set, but it's still a Roland format.
Guess what, they can't be converted to Mach5. :roll:
Although UVI sees the disc, it doesn't see any files inside.
