firewire cables?
eyeknow
firewire cables?
Post by eyeknow »
Has anyone ever heard a difference in sound quality in fw cables?
anyone?
ever?
eyeknow
Post by eyeknow »
BUMP
chorga1
Post by chorga1 »
Seriously doubt it. It's just sending 1s and 0s.
Smokehouse
Post by Smokehouse »
Not sound quality, but occationally I have seen posts where someone fixed a problem with system stability (computer crashing, dropouts, unit resets, etc.) by replacing the firewire cable. But sound quality? Not a chance.
"I'll try anything twice."
Dell Latitude E6400 w/ WIN XP SP3, ADS Pyro 1394 FireWire
SONAR 8.5, WaveArts TrackPlus & MasterVerb, AutoTune 4.1
MOTU 828 MKIII, MOTU 828mkII, Presonus Digimax LT
djencode
Post by djencode »
i disagree on one basis. ground looping causing line noise. i had a problem with the mbox where i had a huge noise floor and i didn't know why. turns out i didn't have shielded usb cable and it was causing a ground loop.
but as far as the clairity of the signal, they are right it wouldn't. however better cable can help conductivity, which would make say, more data to be able to be transfered across, or less data loss from transfer.
gott ist im khaos gestorben
chorga1
Post by chorga1 »
Of course you can buy a better cable for its objective qualities - grounding, better connectors, etc - but in terms of subjective qualities (i.e., does it sound better) there will not be a difference.
fridayspast
Post by fridayspast »
I just moved my computers into another room and needed a longer cable...The tech page says the MK3 can handle audiowire cables up to 60 feet. This cable is 50ft and I am getting crackling on the analog channels...Any Audiowire input on the back of the card (1-4) create the same result...Any ideas???
djencode
Post by djencode »
fridayspast wrote:I just moved my computers into another room and needed a longer cable...The tech page says the MK3 can handle audiowire cables up to 60 feet. This cable is 50ft and I am getting crackling on the analog channels...Any Audiowire input on the back of the card (1-4) create the same result...Any ideas???
try shielded gold plated cable, avoid having the cable in a coil, running across power lines across speakers, monitors, or any other magnetic device.
wow 60 feet. thats also beyond the acceptable distance for cabling too. time to moove your mk3 closer to your computers. they say no more than 25 feet before signal degridation occurs. unless you by super expensive high qual cable of course, but even then it's iffy
Smokehouse
djencode -- ground loops through the FireWire cable. I hadn't thought about that, and I stand corrected. Good thinking.
klk
GOT IT
Post by klk »
WENT TO BUY A NEW FIREWIRE GOLD CABLE AND NOW NO MORE STOPS OR CRACKLES ON THE ULTRALITE......
THE CABLE IS CALLED PROFIGOLD (by bandridge) , it says that is has 24k gold plated contacts that ensures optimum signal transfer...
I HOPE THIS HELPS OTHER PEOPLE TOO
THANKS A LOT FOR ALL THE ADVICES AND NOTES,
LUIS O.
Smokehouse
Is the 24k plating compatible with 96k sampling? :wink:
djencode
Post by djencode »
holy ••••, so my cable was causing my problems o.O
time to swap out cables :D
klk
DO NOT KNOW
Post by klk »
I DO NOT KNOW IF 24K GOLD CONNECTIONS IS COMPATIBLE WITH 96KHZ RECORDINGS....
ANYONE KNOW????
mr whippy
Post by mr whippy »
After heavy research, talking to MOTU customer service AND several jewelers... everyone seems to think compatibility shouldn't be an issue!
djencode
Re: DO NOT KNOW
Post by djencode »
klk wrote:I DO NOT KNOW IF 24K GOLD CONNECTIONS IS COMPATIBLE WITH 96KHZ RECORDINGS....
ANYONE KNOW????
dude it was a joke XD
