MTPAV AC HUM ISSUE HELP!
Timeline
Post by Timeline »
I have a major ground hum when I powerup the MTPAV now. Just happens in all my unbalanced audio sources and M-Audio speakers.
It appears to NOT be a ground loop and rather something in the PSU that is emenating all over my system via ac.
The MTPAV seems to still work, strangly enough.
Anyone else heard of this?
Sticky Fox
Post by Sticky Fox »
It could be a ground loop if you're using USB. I'm not sure how you'd address it. Perhaps you can lift the ground on the MTPAV?
If it's a 60Hz noise you're hearing, it's not getting into your monitors through the AC.
Timeline
Post by Timeline »
Sticky Fox wrote:It could be a ground loop if you're using USB. I'm not sure how you'd address it. Perhaps you can lift the ground on the MTPAV?
Yea thanks. tried the lift and no dice. It's usb. I'll mess with it at the end of the week.
Cheers
Sticky Fox
Timeline wrote: Yea thanks. tried the lift and no dice. It's usb. I'll mess with it at the end of the week.
Drat.. That's a really weird place for a hum to be coming from. Are you using MIDI only, or do you have the timecode/word sync or anything else connected?
Timeline
Post by Timeline »
It seems to eminate out the ac line as noise. using Mackie control, a few synths too but no big setups like TC lockup or anything
