g4 dual 867mhz cannot load more than 2 sounds in machfive without overloading cpu. any way around this or do i need a cpu upgrade.
thanks.
cpu drama
Re: cpu drama
Have you raised your buffers? This always helps me when loading multiple VIs. For latency, try using CueMix if you have it.guitarsark wrote:g4 dual 867mhz cannot load more than 2 sounds in machfive without overloading cpu. any way around this or do i need a cpu upgrade.
thanks.
You also should factor in RAM (if you're loading samples in conventionally) or hard drive speed (if you're streaming samples). Moreover, compounded UVI processing effects within M5 can sometimes tax your procs.
That said, my experience has been that G5s handle VIs and soft samplers much more efficiently than G4s. If it's within your budget to upgrade, you'll definitely benefit from the step.
