cpu drama
guitarsark
cpu drama
Post by guitarsark »
g4 dual 867mhz cannot load more than 2 sounds in machfive without overloading cpu. any way around this or do i need a cpu upgrade.
thanks.
Frodo
Re: cpu drama
Post by Frodo »
guitarsark wrote:g4 dual 867mhz cannot load more than 2 sounds in machfive without overloading cpu. any way around this or do i need a cpu upgrade.
thanks.
Have you raised your buffers? This always helps me when loading multiple VIs. For latency, try using CueMix if you have it.
chrispick
Post by chrispick »
You also should factor in RAM (if you're loading samples in conventionally) or hard drive speed (if you're streaming samples). Moreover, compounded UVI processing effects within M5 can sometimes tax your procs.
That said, my experience has been that G5s handle VIs and soft samplers much more efficiently than G4s. If it's within your budget to upgrade, you'll definitely benefit from the step.
Frodo
Post by Frodo »
Chris is right. The faster bus speeds and the faster RAM speed of G5's are among the biggest benefits in this regard. Two instances of Altiverb sent my old G4 into virtual meltdown.
guitarsark
my buffer size is 512 which is the highest dp will let me go (higher ones are greyed out). is there anything else i can do? just got this g4 so upgrading to g5 is not an option right now. i am using machv sounds, not importing anything from outside the program. thanks.
Shan
Post by Shan »
i use the M5's PC Version,i found the effects have many bugs turn up your cpu to 99% still waiting for the version V2 ,but i advice fixed those problem's for V1 user first :evil:
if you want it works ,don't use M5's effects.
