open song = DP crash
TOD
Post by TOD »
OKay, so I started this track saturday. left it alone sunday. Monday one of my external Lacie drives starts making funny noises. (obviously ready to die). So me dumb-ass pulls out the USB chord of my MTPAV by mistake...I don't remember if my song was up. As I recall, I had everything including the computer off. Now This one file will not open. When I launch DP and then select the file, DP just quits, no warning no "unexpectedly quit message" Nothing.
My other files seem to open fine. This file has all the correct parts, the file, Audio Folder, Analysis Folder and Undo Folder. I can see the audio files in the folder. What I really miss is the MIDI, I had some sweet piano parts going.
I've repaired permissions, ran disk warrior, copied the file to multiple drives, de-installed and re-installed DP, and downloaded all the latest DP updates. I'm at my wit's end. Any help or should I just let it go?
My system is usually rock solid. I mean I crash maybe once every 6 months.
Thanks Tod
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few :)
digsy
Post by digsy »
this happened to me once...
i copied the project folder to another drive and opened it from there and all was fine.
if this does not work then create a new account in osx - call it "studio" or whatever. log in and launch dp and your project. one of these methods should work for you.
good luck
digsy
Post by digsy »
:arrow: good luck
TOD
Post by TOD »
Thanx, I'l give both those ideas a try
bralston
Post by bralston »
Or you could open a new blank DP file and use the load feature to load the older sequence (from the file in question) into the new file. Sometimes the load feature is a good way to open otherwise corrupted files that will not open normally.
Regards,
Brian Ralston
Frodo
Post by Frodo »
Great suggestion, Brian.
.. or should we call you "Brain"? :lol:
TOD
Post by TOD »
I can see hear the audio files in the audio folder so I should have no problem loading them, but what about the MIDI? am I SOL?
Frodo
Post by Frodo »
The Load feature didn't work?
tripit@earthlink.net
Post by tripit@earthlink.net »
I had an issue along the same lines, and it turned out that I had to trash all my DP prefs to fix the problem.
TOD
Post by TOD »
Frodo wrote:The Load feature didn't work?
Will be tryng tonight.
Should I trash the whole prefernces Folder? or just waht's inside?
jeb jerome
Post by jeb jerome »
Same problem and Load started to work, but then crashed. Damn. I had even created another file as a backup before the crashes started, but neither of them work.
sschweyen
Post by sschweyen »
I know this is an old post, but I wanted to offer my experience to anybody who might be searching for this problem. I had the same problem with a file. every time I opened it, it would crash and give me the "unexpectedly quite" message. Even tried what bralston said. Nothing, same problem.
I transfered the file onto my i book, which has DP also and it loaded fine. I do not have all my plugs loaded on my ibook that I have on my tower, so that must have something to do with it. If you don't have another computer you could try loading it on a friends mac (that is if they have DP) Hope that helps.
Dual G5 1.8 1.25 Gb RAM / DP 5.13 / Reason 4.01 / Recycle 2.5 / Logic Express 7, Logic 8, various soft synths n' stuff
sndhse
Post by sndhse »
TOD wrote:I can see hear the audio files in the audio folder so I should have no problem loading them, but what about the MIDI? am I SOL?
TOD, here's another few possible options you could try.
1) Hold down the shift key and load DP, this will disable your audio drivers and any plugins. DP will load up in "MIDI only mode" at this point you could 1) resave the file (DP document) or 2) create a standard MIDI file then drag that file into a new document, or 3) "Save as copy" with "Duplicate audio" checked. Close and Quit DP. Fire Dp backup, without holding the option key,
and try to open the new bkup you saved.
Hope this can help you
John
G5 Quad 6.5GB ram/2408MKIII/MTPAV/Mackie d8b
DP 6.01/OS 10.4.11
B4, Kontakt 2, Absynth 3, Stylus RMX, Ivory 1.5, Addictive Drums, Sampletank 2, Ivory, East west Gold/XP, East West Symphonic Choirs, Reason 2.5, Waves Platinum, Altiverb, Vst Wrapper etc...
sschweyen
Post by sschweyen »
ahh...good idea... I was gonna ask if theres anyway in those circumstances to load DP in some sort of "safe mode"
