open song = DP crash
OKay, so I started this track saturday. left it alone sunday. Monday one of my external Lacie drives starts making funny noises. (obviously ready to die). So me dumb-ass pulls out the USB chord of my MTPAV by mistake...I don't remember if my song was up. As I recall, I had everything including the computer off. Now This one file will not open. When I launch DP and then select the file, DP just quits, no warning no "unexpectedly quit message" Nothing.
My other files seem to open fine. This file has all the correct parts, the file, Audio Folder, Analysis Folder and Undo Folder. I can see the audio files in the folder. What I really miss is the MIDI, I had some sweet piano parts going.
I've repaired permissions, ran disk warrior, copied the file to multiple drives, de-installed and re-installed DP, and downloaded all the latest DP updates. I'm at my wit's end. Any help or should I just let it go?
My system is usually rock solid. I mean I crash maybe once every 6 months.
Thanks Tod
Thanks Tod
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few
Thanx, I'l give both those ideas a try
- bralston
Or you could open a new blank DP file and use the load feature to load the older sequence (from the file in question) into the new file. Sometimes the load feature is a good way to open otherwise corrupted files that will not open normally.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
I can see hear the audio files in the audio folder so I should have no problem loading them, but what about the MIDI? am I SOL?
Will be tryng tonight.Frodo wrote:The Load feature didn't work?
Should I trash the whole prefernces Folder? or just waht's inside?
- sschweyen
I know this is an old post, but I wanted to offer my experience to anybody who might be searching for this problem. I had the same problem with a file. every time I opened it, it would crash and give me the "unexpectedly quite" message. Even tried what bralston said. Nothing, same problem.
I transfered the file onto my i book, which has DP also and it loaded fine. I do not have all my plugs loaded on my ibook that I have on my tower, so that must have something to do with it. If you don't have another computer you could try loading it on a friends mac (that is if they have DP) Hope that helps.
Dual G5 1.8 1.25 Gb RAM / DP 5.13 / Reason 4.01 / Recycle 2.5 / Logic Express 7, Logic 8, various soft synths n' stuff
- sndhse
TOD wrote:I can see hear the audio files in the audio folder so I should have no problem loading them, but what about the MIDI? am I SOL?
TOD, here's another few possible options you could try.
1) Hold down the shift key and load DP, this will disable your audio drivers and any plugins. DP will load up in "MIDI only mode" at this point you could 1) resave the file (DP document) or 2) create a standard MIDI file then drag that file into a new document, or 3) "Save as copy" with "Duplicate audio" checked. Close and Quit DP. Fire Dp backup, without holding the option key,
and try to open the new bkup you saved.
Hope this can help you
John
G5 Quad 6.5GB ram/2408MKIII/MTPAV/Mackie d8b
DP 6.01/OS 10.4.11
B4, Kontakt 2, Absynth 3, Stylus RMX, Ivory 1.5, Addictive Drums, Sampletank 2, Ivory, East west Gold/XP, East West Symphonic Choirs, Reason 2.5, Waves Platinum, Altiverb, Vst Wrapper etc...
DP 6.01/OS 10.4.11
