Sequoia and USB Issues
Re: Sequoia and USB Issues
Post by Rick Cornish »
CharlzS wrote:Don't know if related, but had difficulty with drive not being recognized. Found a suggestion somewhere (maybe here) to change setting System Settings --> Privacy and Security --> Accessories --> Allow Accessories to Connect to "Ask for New Accessories". Disconnected the device, changed the setting, restarted, plugged in drive and responded to prompt. I have not had issue since.
Thanks, CharlzS, I’ll check it out
CharlzS wrote: Tue Apr 22, 2025 3:18 am Don't know if related, but had difficulty with drive not being recognized. Found a suggestion somewhere (maybe here) to change setting System Settings --> Privacy and Security --> Accessories --> Allow Accessories to Connect to "Ask for New Accessories".
There is an option to ALWAYS allow. Since my laptop is lives at home and rarely goes with me; is there any reason not to use "always"?
CharlzS wrote: Tue Apr 22, 2025 3:18 am Don't know if related, but had difficulty with drive not being recognized. Found a suggestion somewhere (maybe here) to change setting System Settings --> Privacy and Security --> Accessories --> Allow Accessories to Connect to "Ask for New Accessories". Disconnected the device, changed the setting, restarted, plugged in drive and responded to prompt. I have not had issue since.
On my system (in Sequoia) there's no menu option for "Accessories" under Privacy & Security. I didn't find Quartet under any of the dozen or so other categories, though I did find Apogee Control 2 (the controller app for Quartet) in the Microphone menu and it was enabled.
CharlzS
Post by CharlzS »
stubbsonic wrote: Tue Apr 22, 2025 7:58 am
Mine was set to "Always" and the thread that I found said to change that - there might be some issue with the Always setting.
CharlzS
Post by CharlzS »
Rick Cornish wrote: Tue Apr 22, 2025 8:15 am On my system (in Sequoia) there's no menu option for "Accessories" under Privacy & Security. I didn't find Quartet under any of the dozen or so other categories, though I did find Apogee Control 2 (the controller app for Quartet) in the Microphone menu and it was enabled.
Maybe it's just a laptop thing? It's at the bottom of my Privacy and Security settings after FileVault.
CharlzS wrote: Tue Apr 22, 2025 10:52 am Maybe it's just a laptop thing? It's at the bottom of my Privacy and Security settings after FileVault.
You are correct, sir!
Security settings from my MacBook Pro…
Screenshot 2025-04-22 at 1.12.04 PM.png (64.5 KiB) Viewed 743 times
And from my Mac Studio…
Screenshot 2025-04-22 at 1.11.31 PM.png (58.31 KiB) Viewed 743 times
As an aside, it was always annoying to me that Mac OS might prevent me from opening a newly installed app-- UNLESS I knew the "cheat code" which is to right-click and choose open from the contextual menu. Now Mac OS has replace this with a new cheat code: go to System Settings/Security & Privacy and scroll to the bottom and choose open anyway.
Me: "Um, so you won't let me. ... but you will let me, if I know the secret ways."
stubbsonic wrote: Wed Apr 23, 2025 7:56 am As an aside, it was always annoying to me that Mac OS might prevent me from opening a newly installed app-- UNLESS I knew the "cheat code" which is to right-click and choose open from the contextual menu. Now Mac OS has replace this with a new cheat code: go to System Settings/Security & Privacy and scroll to the bottom and choose open anyway.
In this case, "the secret way" is to unplug the usb cable from the back of my interface and plug it back in again.
