CharlzS wrote:Don't know if related, but had difficulty with drive not being recognized. Found a suggestion somewhere (maybe here) to change setting System Settings --> Privacy and Security --> Accessories --> Allow Accessories to Connect to "Ask for New Accessories". Disconnected the device, changed the setting, restarted, plugged in drive and responded to prompt. I have not had issue since.
Thanks, CharlzS, I’ll check it out
CharlzS wrote: ↑Tue Apr 22, 2025 3:18 am
There is an option to ALWAYS allow. Since my laptop is lives at home and rarely goes with me; is there any reason not to use "always"?
On my system (in Sequoia) there's no menu option for "Accessories" under Privacy & Security. I didn't find Quartet under any of the dozen or so other categories, though I did find Apogee Control 2 (the controller app for Quartet) in the Microphone menu and it was enabled.
Mine was set to "Always" and the thread that I found said to change that - there might be some issue with the Always setting.
Rick Cornish wrote: ↑Tue Apr 22, 2025 8:15 am
Maybe it's just a laptop thing? It's at the bottom of my Privacy and Security settings after FileVault.
CharlzS wrote: ↑Tue Apr 22, 2025 10:52 am
You are correct, sir!
Security settings from my MacBook Pro…
Screenshot 2025-04-22 at 1.12.04 PM.png (64.5 KiB) Viewed 737 times
And from my Mac Studio…
Screenshot 2025-04-22 at 1.11.31 PM.png (58.31 KiB) Viewed 737 times
As an aside, it was always annoying to me that Mac OS might prevent me from opening a newly installed app-- UNLESS I knew the "cheat code" which is to right-click and choose open from the contextual menu. Now Mac OS has replace this with a new cheat code: go to System Settings/Security & Privacy and scroll to the bottom and choose open anyway.
Me: "Um, so you won't let me. ... but you will let me, if I know the secret ways."
stubbsonic wrote: ↑Wed Apr 23, 2025 7:56 am
In this case, "the secret way" is to unplug the usb cable from the back of my interface and plug it back in again.
