error/ "takefile disabled for recording"
J.B.
Post by J.B. »
anyone recognize this series of messages?
"an unexpected error occured with one of the record enable takefiles."
"the takefiles have been disabled for recording."
everything seems to be fine except that i can't record anything.
any ideas?
rawk on.
blue
Post by blue »
couple of ideas.
- make sure you have enough space on the disk you're capturing to.
- try checking the permissions on the takefile folder. they may be set to read only.
-try choosing a different location to record to.
hope that helps.
J.B.
Post by J.B. »
thanks for your reply.
how does one check the permissons on the takefile folder?
:roll:
rawk on.
blue
Post by blue »
J.B. wrote:how does one check the permissons on the takefile folder?
first of all, make sure your takefile is where it is supposed to be (ie. not a cd-rom). if it's in the project's audio files folder (the default), go to that folder in the finder. select it and hit command-i. there you will see the read/write permissions. set it to read/write if it isn't already.
J.B.
Post by J.B. »
thanks for this,
the takefiles are safely tucked away in the audio files folder as you suggest. the permissions are set to read/write.
there should be plenty of space on the disc i'm using to store stuff. 9.8 GB to be exact.
could it be a problem with the disc?
rawk on.
blue
Post by blue »
J.B. wrote:could it be a problem with the disc?
could be, though i doubt it.
next things i would try are••¦
1. repair permissions.
2. check the read/write status of all the folders leading to the audio files folder. (you could change them to read/write for the entire disk, or check "ignore ownership")
2. try changing the takefile to another location, preferably another disk or partition.
3. see if the problems exists for other files to rule out a corrupted file.
good luck.
mhschmieder
Post by mhschmieder »
That sounds very extreme, and overkill unless proven necessary.
I have this error pop up every few days or so. I have an underpowered 800 MHz iMac with 384 Mb RAM, so I do not expect my music software to work miracles given what I'm running it on.
My best protection against this error is to save after every little thing that I do in DP, then wait a few seconds before taking a new action.
When the error crops up, it is often sufficient to do a save and/or close/reopen the project.
At other times, I simply re-click on the output and/or input for the disabled takefile.
In other cases, I discover that I hadn't upped my studio size under the configurations. Although DP now seems to automatically adjuist in many cases, it still seems to help to recheck the studio size now and then if performance is getting sticky or errors are popping up that disable a track.
J.B.
Post by J.B. »
checking' ignore ownership' seems to have done the trick.
the pull down menu now says read and write where before it was greyed out.
i confess i don't know what it means but i suppose that's a query for a different forum.
thank you blue, for taking time out of your day to help me out. much appreciated.
rawk on.
blue
Re: or check "ignore ownership"
Post by blue »
J.B. wrote: thank you blue, for taking time out of your day to help me out. much appreciated.
no worries. glad it worked out.
