Falcon and Sonoma
gavspen
Falcon and Sonoma
Post by gavspen »
Hi All,
Not sure if this is the place to post, but....
I know many are using Falcon. Sonoma is not officially supported, but UVI say that things seem to be going ok, no reported problems.
What is the general consensus around here?
Thanks,
Gavin
Mac mini M1, 14.7, 16gigs RAM, 828 mk3 Hybrid, DP 11.31, Various VIs
Michael Canavan
Re: Falcon and Sonoma
Post by Michael Canavan »
I'm on Sequoia with Falcon and no issues. Of course we all do things differently but so far everything is working fine. I use the MPE presets and host UVI sample libraries in it with no weirdness yet.
In general considering UVI/Falcons legacy with MOTU I can't name an issue I've had with Falcon in DP? That's the realm of IK, NI and Akai (InMusic in general) here. Those personally are the companies that will have issues with OS updates and DP.
I was on the UVI site this morning and Sonoma was listed in the System Requirements. Sequoia was not but, as Michael has reported, it works fine for me, too.
mikehalloran wrote: Thu Jan 16, 2025 10:44 pm I was on the UVI site this morning and Sonoma was listed in the System Requirements. Sequoia was not but, as Michael has reported, it works fine for me, too.
Working fine on Sequoia here also. :)
gavspen
Post by gavspen »
Thank you gentlemen, good to know.
Gavin
gavspen
Post by gavspen »
What version are you guys using?
I have 2.8.2 and it looks like v3 will cost me $299. At least that's the price in the cart, which is weird, because the cross grade from Mach5 v3 (which is most certainly the way I got Falcon) is only $179
gavspen wrote: Fri Jan 17, 2025 2:18 pm What version are you guys using?
Yikes! :shock: That sounds pretty brutal. I would submit a ticket to UVI support and plead your case. They tend to be understanding and lenient on some of these things if you contact them privately. I can't see how they wouldn't make SOME kind of accommodation!
CharlzS
Post by CharlzS »
Are you using the UVI portal for software updates? IIRC, the V3 update was no charge. If you're not seeing that in the portal, drop tech support a line.
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
gavspen
Post by gavspen »
You know I forgot all about the UVI portal. Doh! I was looking for an update button on the plugin itself, or thought the web site would recognise me when I logged in, or something.
Anyway, that worked. Thanks for the reminder CharlzS. :D
FYI... for anyone who doesn't have Falcon yet... there's a pretty killer deal going on at Image Line's website. Falcon plus 19 expansions for $199! Even if you half Falcon but not many expansions, might be worthwhile!
https://www.image-line.com/specials/uvi-falcon
gavspen
Post by gavspen »
James Steele wrote: Thu Jan 23, 2025 5:23 pm FYI... for anyone who doesn't have Falcon yet... there's a pretty killer deal going on at Image Line's website. Falcon plus 19 expansions for $199! Even if you half Falcon but not many expansions, might be worthwhile!
That does seem like a great deal. Go for it, kids. :D
