OG MIDI Timepiece ONE
Terra303
Post by Terra303 »
Hi Everyone! This question is gonna take everybody WAY BACK...
I know this is a long shot, but a couple of months ago I bought an old MIDI Timepiece One because I want to try to set up a MIDI sequencing setup around an old Macintosh SE running Performer 4.2. The only thing is that I had forgotten that the MTP needs software to run. Back in 1996 I remember buying a used MTP II, and I had forgotten that it came with disks to install the MTP II Console (it turns out I still have a compressed version of that installer). While I had read that the MTP II Console also works with the MTP I, it only runs in Mac System 7 or above because it needs FreeMIDI to run). Just for giggles I did write MOTU to see if they had a copy of the MTP I desk accessory installer, but their archives dont go back that far...
I'm trying to avoid installing System 7 on this Mac because I hear that it runs crazy slow on the Mac SE... So I'm asking if anyone of you folks may have a copy of the MTP I desk accessory installer somewhere in your archives, either on a floppy disk or disk image (or a stuffit file).
Thanks in advance... We now return you to 2024...
M2 Ultra Mac Studio (64GB RAM), 16" MacBook Pro (8 core 2.4 GHz i9, 32GB RAM, AMD Radeon Pro 5600M), Mac OS 14.6.1, MOTU DP 11.02, MachFive3.2.1, 828x, MTP AV, Roland XP-10, DJ-70, SH-101, MC-202, TB-303, RE-201, E-Mu Morpheus, Planet Earth, Moog Slim Phatty, Novation DrumStation, Oberheim OB-1, Yamaha 01V96v.2, DR-220, Casio PT-80, VL-1, SK-5, Focal CMS 50s
Re: OG MIDI Timepiece ONE
That's surprising because System 7 did not slow down my Mac Plus.
Like many of us here, I used to have all those disks but they went out in a purge 20 years ago or so..
IIRC, system 7 did run a lot slower than 6 if you had a mac without sufficient RAM.
As for the discs, I’ve seen links to old mac stuff that was moved to the public domain. I think one of several MacAttorney lists might be a place to look for it.
Terra303
Post by Terra303 »
Ok so to update on my situation:
I tried to install System 7.1 and FreeMIDI. Apparently FreeMIDI needs at least 8 MB to run. I was able to install it with only 4 MB, but anything I tried to run after that would crash. No dice...
Finally I ended up finding another MTP I online in its original box, with manual and install disks. I ordered it, not knowing if the disks were still any good, or if the floppy drive in my SE was still working... I took apart the drive and cleaned it, then tested it with a blank disk I had the day before I was supposed to receive the MTP. Even the day I got the MTP, I just put the disk in, and copied the contents to the internal drive before ejecting the disk... Everything worked well...
So yes, you do need the MTP I Desk Accessory in order for the Mac to see the MTP. Performer 4.2 works great with the Mac SE in System 6.0.8 (although I am going to get a 68030 accelerator board because the refresh rates are painfully slow). Its also nostalgic running this 30 year old version of Performer and re-learning how to MIDI sequence my old hardware without some "old" Performer features (like not having detailed tracks in the tracks window (just grey/black bricks), split notes automatically pasting on its own separate tracks, etc.)...
