Blue3 organ produces clicks
Jim
Post by Jim »
Has anybody else bought or demoed the new Blue3 organ VI from Cherry Audio? It's only been out for about a week.
I'm experiencing the VI going into a non-functioning mode by introducing a low volume clicking sound and the loss of the organ sound.
The only pattern I've noticed is the issue manifests when I switch apps, and then back again to DP.
While it's working, it sounds great to me - better than the Arturia B3 and the AIR DB-33 I bought on sale for $9 years ago.
I reported this to Cherry Support. They said the clicking is a known issue they are investigating, and suggested toggling some of the parameters to bring the sound back. I told them that doesn't work for me, and they suggested the bug may be exaggerated in DP. So, I'm asking to see if I'm the canary in a coal mine.
Thanks.
Re: Blue3 organ produces clicks
Surest way to restore any misbehaving VI in DP: Disable, then re-enable the VI using the "Enable" button in the Tracks Window. If you don't see the Enable button, open the Tracks Window Mini Menu and make it visible.
HC Markus
https://rbohemia.com
I have to confess this ENA(ble) column has completely flown under my radar. I don't even want to know how long it has existed-- could be embarrassing.
stubbsonic wrote: Mon Sep 16, 2024 9:04 am I have to confess this ENA(ble) column has completely flown under my radar. I don't even want to know how long it has existed-- could be embarrassing.
No worries! But it is super useful, especially when you set up a giant template and don't want all the unused tracks/VIs loading your system down. In my template, almost everything is disabled to start except Buses and FX Returns. Opens in a flash, tracks enabled as needed.
HCMarkus wrote: Mon Sep 16, 2024 9:52 am
Power tip!! Thank you so much.
Jim
Post by Jim »
HCMarkus wrote: Mon Sep 16, 2024 8:17 am Surest way to restore any misbehaving VI in DP: Disable, then re-enable the VI using the "Enable" button in the Tracks Window. If you don't see the Enable button, open the Tracks Window Mini Menu and make it visible.
I hadn't thought of trying that. I just edited a Sequence with the Blue3, and it was sounding during playback. I bounced it and the organ had disappeared.
I then toggled the ENA button, and the sound returned!
Thanks for the suggestion.
You're welcome gents!
