Wish list For DP 5.1 (or DP5?)
blue
Post by blue »
Tim wrote:User chooses default pencil tool in the MIDI edit window, or make it stay where I last left it instead of defaulting to Pitch Bend. Or is pitch bend the most used tool (I use ?#7 the most)? I know that seems like a minor thing, but it's bugged me for years.
word.
more user defined defaults would be good in general. like automation curve types, modes and status (on/off).
also, i would love to see contextual menus for things like changing automation layers and tools.
grimepoch
Post by grimepoch »
blue wrote: also, i would love to see contextual menus for things like changing automation layers and tools.
I'd like to see stackable automation layers, so they aren't over each other. Also, if I select a controller I'd like to automate, I'd like that to stay selected in the automation window, not switch to something else.
I start getting a few controllers and it just gets complicated after a bit
[MacPro-4x2.66/7G/OSX10.5.2 - 2x896HD - ADA8000 - Lucid Genx6 - DP5.13 - Logic 8.02 - 2xUAD1e - ExpressXT - Mach5 - MX4 - Korg LegD - impOSCar - Battery3 - uTonic - Rapture - DimPro - Vanguard - Reaktor5 - Absynth4 - FM8 - Pro53 - Vokator - Waldorf Ed - Addictive Drums - Melodyne - Ultra Analog - Zebra2 - WaveArts - - Altiverb - Etc. ]
[Virus TI - Virus B - Waldorf Q - Waldorf uwXT - Supernova II - Nord Rack 3 - JP8080 - XV5080 - Fantom X7 - Triton Rack - Pro/cussion]
boonier
Post by boonier »
Rush909 wrote:I'll play along...
3. usable track Freeze feature (ala Logic, etc...)
I'm pretty surprised that this hasn't been addressed even in this upgrade. I get the impression that its been an issue long before I ever started using DP.
Motu, "with all these features you are spoiling us" (Ferrero Rocher ad? - sorry crap joke) but I think this is more important than new synths , that we'd still have to freeze using the same old process may I add....
1ghz 17" Powerbook (currently), 1gig ram, Tiger 10.4.8, DP 4.6.1, Motu 828, Edirol FA-101, Bidule, Reason, SuperCollider, synths, hardware FX, cables, plugs, plug adaptors, extension leads, dust, vacuum cleaner
chaim
Post by chaim »
dpdan wrote:A rolling MIDI edit, in other words, the ability to highlight two MIDI notes that overlap each other, and only move the transition of those notes to each other, earlier or later.
That would be great. I spoke to Dave Roberts about this at AES he said that would be great!
Yes. Count me in for this one.
This is actually coming in DP5 but for Audio sound-bites.
blue
Post by blue »
sub-menus for input bundles! when you're running multiple vis, the new bundles list gets unwieldy fast. it would be nice if the menus were divided by type (buses, inputs, kontakt, live, reason, etc.)
dpdan
Post by dpdan »
It would be great to be able to highlight a number of tracks in the tracks window and move them together. For instance, grab all the strings tracks, and put them at the top or somewhere else in the list.
Perhaps command/drag
dpDan
Tim
Post by Tim »
dpdan wrote:It would be great to be able to highlight a number of tracks in the tracks window and move them together. For instance, grab all the strings tracks, and put them at the top or somewhere else in the list.
Control+Home = Top
Control+End = Bottom
Control+Page Up = Up
Control+ Page Down = ?
Option+Control+Home = Move Together (up)
So if you wanna move a group of tracks to a specific spot, without moving one space at a time, Shift-select the tracks to be moved, then Shift-select the track (above them) that you want them to end up below, hit Opt+Cntrl+Home. If the desired destination is below the tracks, move them all to the bottom first.
BTW: These operations take a little time, so you might think it's not doing anything after hitting the command.......give it a few seconds.
dpdan
Post by dpdan »
I'll try it thanks alot!
Dan
dpdan
Post by dpdan »
Tim, your instructions are not working.
If I shift click five tracks, they are highlighted.
Then you say shift select the track name that you want them to end up below. If I shift select again, it unhighlights the tracks I want to move.
I might be misunderstanding your term shift select.
Please advise... Thanks Tim,
Dan
blue
Post by blue »
works for me. tim, you are a wealth of information. i knew about all those except the shift one to get tracks to go to a certain location. brilliant!
thanks.
magicd
Post by magicd »
And just to be thorough, the commands for moving tracks around are found in the Commands window and you can edit the key strokes if you like.
The Commands window is actually a killer way to get into DP. You can learn a lot about DPs capabilities just by browsing this window.
Magic Dave
Tim
Post by Tim »
dpdan wrote:Tim, your instructions are not working.
That sounds right to me.
As long as you're not clicking before pressing (and holding) the Shift key, I don't know why he other tracks would deselect.
The track that the others are to be moved near can be selected at the same time (same holding of the shift key) as the others. I didn't necessarily mean that it had to be a separate thing. Still, you should be able to go away for an hour, come back and shift select a track without the others deselecting.
Tim
Post by Tim »
Yeah Man!
I never read the manual (not that one shouldn't), I just browse the Commands window. And that it has a search function makes it doubley killer (or is it, 'Dolby'?)!
brood
Post by brood »
dpdan: Also it would be cool if the ruler bar "measures" could display time or measures.
If I understant ya, you can actually do this. Just go the Set Up>Time Format, & just choose what ya wanna see as the format for the Time Ruler.
kelldammit
Post by kelldammit »
Tim wrote:
Yeah Man!
man, great info there. being a new user, that's where i'll start spending more time. and, btw, it's "dolby". you mix your albums (particularly black ones) in doubly.
:D
