Hello guys,
As the title says, I have no sound except my daw. Is there a particular thing that I'm missing?
Thank you,
No sound outside my Daw in Motu Ultralite MK3 win 10
Re: No sound outside my Daw in Motu Ultralite MK3 win 10
Hello,
I just saw your post. Have you found a solution? It's been awhile since your post, but just in case, I would suggest you take a look at Windows' Sound Settings to ensure the MOTU's Main Outs are selected. I attached a screen shot.
You can also access that function by right-clicking on the icon that looks like a speaker on the taskbar, and selecting Sounds. The interface is different from the one above, but the advantage is that you can do a lot in a compact UI.
- SoundSettings01.jpg (112.47 KiB) Viewed 1158 times
- SoundSettings02.jpg (63.07 KiB) Viewed 1158 times
Hi,
No I haven't figure it out. I did what you mentioned in your reply with no results.
I have changed the sample rate from the windows settings. That was the reason.
