Hello,
I have changed my system from TB to DANTE with DP 11.02 on Mac Pro Desktop late 2013 with Big Sur.
I have a small stuff: my Hardware Dante Device is my Lynx Aurora'n Converter, Netgear Gigabit Ethernet Plus Switch(GS308E), 4 Avid Artist Mix Controllers.
The problem is: when I'm starting my System it's running about 10 minutes and then the Mac crashes. ( No crash on my Lynx ) When I start the Mac again, the system is running perfect without any problems and a lot of hours.
But next day I have the same issue !
In my opinion the bug is certainly on DP, because when I open my system without DP it don't occur some crashes !
BTW: all Hardware stuff on newest drivers incl. the Dante DVS-Version !
Is there someone to know problems with DANTE ?
Thanking you in anticipation !
Problem with DANTE
Problem with DANTE
Only a Tele is good enough !!!
Re: Problem with DANTE
A crash log would certainly help... I believe you can't shut off the energy saving feature of that Netgear piece. One of the first Dante to dos is to shut off Energy Savings in the switch you're using. Might be a place to start your troubleshooting.
Thanks a lot for your help ! Yes, my switcher was wrong, now I have a managed switcher and it's running perfect
Greets lito
