FYI...DP 11.01 is out
Re: FYI...DP 11.01 is out
HCMarkus wrote: Tue Sep 14, 2021 4:37 pm Impressive list of fixes. Thanks for sharing.
Yeah Brother Sir Markus; that's a Helluva list of fixes. :headbang:
Thank you for the heads-up, Brian. :wink:
fdco
Post by fdco »
dewdman42 wrote: Tue Sep 14, 2021 11:10 am I just tried with the disable crash reporter option, get the same crash either way...
Guess I have to roll back to 11.0, have submitted a ticket to MOTU already.
Same here,
Looking at the apple crash report, it looks like it's a rewire issue:
Code: Select all
se.propellerheads.rewire.library	0x0000000120a565fb RWIsReWireMixerAppRunningImp + 11451
9   se.propellerheads.rewire.library	0x0000000120a5b6af RWIsReWireMixerAppRunningImp + 32111
10  se.propellerheads.rewire.library	0x0000000120a5bf92 RWIsReWireMixerAppRunningImp + 34386
11  se.propellerheads.rewire.library	0x0000000120a538e5 RWM2OpenImp + 85
The workaround for me is to launch a rewire app (logic in my case) then launch DP.
Will report to motutech.
Mac Book Pro M1 32gb -2TB,
Apogee Symphony Thunderbridge,
DP11, MTPAV, Linnstrument, Chapman Stick
Sergievsky
Post by Sergievsky »
No go here. After doing the plug-in disable dance, I manually dragged all the AU and VST out of the Library and it still crashed on launch. Gonna try to go back to 11.0. This is really a downer... :cry:
Michael Canavan wrote: Tue Sep 14, 2021 1:00 pm
First thing to do is attempt to open DP without plug ins enabled.
A goofy but often effective fix for weird crashes like this with updates is to move your DP related preferences to the desktop, (in case it doesn't fix the issue you don't have to rebuild your preferences etc.)
Here's the tech link covering this. :)
https://motu.com/techsupport/technotes/ ... 20Glitches
Raul
iMac Pro 3GHZ 10-core, 128GB RAM, 2TB hd, Big Sur
motu 8pre-es
dewdman42 wrote: Tue Sep 14, 2021 10:50 am crashes on load for me.
Shut down before rebooting. See if you still have a problem
If so, launch DP on Safe mode by holding the Shift key. After DP boots, quit and relaunch DP. See if you still have a problem.
Any replies that state one shouldn’t have to do above will be ignored.
ivorysteve
Post by ivorysteve »
dix wrote: Tue Sep 14, 2021 3:48 pm
ivorysteve wrote: Tue Sep 14, 2021 3:26 pm Also opened my latest project and immediately crashed. Reverted back to 11.0. C'mon guys. Regression testing, anyone? Bueller?
Please let us know your specs, your OS at least. That might help folks help you if still you want to update
Just updated my sig. Sorry, it's been awhile since I've responded to threads here. Thanks for the link!
2018 Mac mini 6-core i7 32 GB RAM, UHD Graphics with 2 displays, MacOS Big Sur
2019 MacBook Pro i9 8-core 32 GB RAM, MacOS Big Sur as VEP slave
MOTU M4 audio IF, Monogram CC controller
DP 11
waterstrum
Post by waterstrum »
Sorry to hear about problems with 11.01.
In my case, it is working very well.
Seamless transition from 11.0.
Looks like MOTU is 'on the case' with bug fixes.
I am curious about one new feature... MIDI Track Protocol Settings Window
Not sure where to find it.
The fader height thing is nice, but both medium and tall are way too tall for my use.
Dynamic setting doesn't get the height right for me.
Short is too short.
Not a big deal.
I'm happy that MOTU is continuing to develop and improve DP.
All is well
waterstrum wrote: Thu Sep 16, 2021 12:57 am
Page 147 in the latest manual. BTW, I guess I won't be getting a Roli Seaboard controller.
Michael Canavan
Post by Michael Canavan »
cuttime wrote: Thu Sep 16, 2021 9:45 am
Is this because of the latest news on Roli? I've got a Seaboard Block and a Linnstrument. I do prefer the Linnstrument for multiple reasons, mainly that Linn could go out of business tomorrow and it would still work, and the fingering doesn't lend itself to possible bad technique.
Michael Canavan wrote: Thu Sep 16, 2021 10:32 am
Yep.
dewdman42
Post by dewdman42 »
The key to fixing the dp 11.01 crash is to delete the propellarheads application support folder. There is a rewire driver in there that dp 11.01 is not ignoring even though dp does not officially support rewire any longer.
If you ever run ableton live it may try to repopulate that application support folder again and would later cause dp to crash I guess. I think there is a way to disable ableton from doing that, google it.
But removing the propeller heads application support folder cured the problem. I don’t know what will happen if and when I try to use my reason plugin or ableton live again it might be that I will need to periodically delete this rewire malware.
corbo-billy
Post by corbo-billy »
Especially since the appearance of ReasonRack, no need for the Rewire link ... 8)
sayatnova
Post by sayatnova »
dewdman42 wrote: Thu Sep 16, 2021 11:24 am The key to fixing the dp 11.01 crash is to delete the propellarheads application support folder. There is a rewire driver in there that dp 11.01 is not ignoring even though dp does not officially support rewire any longer.
So, if I don't have or use Reason, but, I have and use Ableton Live 11, this will cause the new DP 11 update to have issues? Just want to check in here before I update!...;-)
Thank you!
http://www.bfdmusic.com
Sergievsky
Thanks, this did it. Thank God for other DP users…
Raul
motu 8pre-es
svobodomo
Post by svobodomo »
BE AWARE!!!
There is extremely bad bug in DP11.01, If you're using any articulation with instrument you cannot normal or retrospective record there... :cry:
svobodomo wrote: Fri Sep 17, 2021 1:24 am BE AWARE!!!
Huh?
