Yeah Brother Sir Markus; that's a Helluva list of fixes.
Thank you for the heads-up, Brian.
Same here,
Code: Select all
se.propellerheads.rewire.library 0x0000000120a565fb RWIsReWireMixerAppRunningImp + 11451
9 se.propellerheads.rewire.library 0x0000000120a5b6af RWIsReWireMixerAppRunningImp + 32111
10 se.propellerheads.rewire.library 0x0000000120a5bf92 RWIsReWireMixerAppRunningImp + 34386
11 se.propellerheads.rewire.library 0x0000000120a538e5 RWM2OpenImp + 85
Michael Canavan wrote: ↑Tue Sep 14, 2021 1:00 pmFirst thing to do is attempt to open DP without plug ins enabled.
A goofy but often effective fix for weird crashes like this with updates is to move your DP related preferences to the desktop, (in case it doesn't fix the issue you don't have to rebuild your preferences etc.)
Here's the tech link covering this.![]()
https://motu.com/techsupport/technotes/ ... 20Glitches
Shut down before rebooting. See if you still have a problem
Just updated my sig. Sorry, it's been awhile since I've responded to threads here. Thanks for the link!dix wrote: ↑Tue Sep 14, 2021 3:48 pmPlease let us know your specs, your OS at least. That might help folks help you if still you want to updateivorysteve wrote: ↑Tue Sep 14, 2021 3:26 pm Also opened my latest project and immediately crashed. Reverted back to 11.0. C'mon guys. Regression testing, anyone? Bueller?
Page 147 in the latest manual. BTW, I guess I won't be getting a Roli Seaboard controller.waterstrum wrote: ↑Thu Sep 16, 2021 12:57 am
In my case, it is working very well.
Seamless transition from 11.0.
Looks like MOTU is 'on the case' with bug fixes.
I am curious about one new feature... MIDI Track Protocol Settings Window
Not sure where to find it.
Is this because of the latest news on Roli? I've got a Seaboard Block and a Linnstrument. I do prefer the Linnstrument for multiple reasons, mainly that Linn could go out of business tomorrow and it would still work, and the fingering doesn't lend itself to possible bad technique.cuttime wrote: ↑Thu Sep 16, 2021 9:45 amPage 147 in the latest manual. BTW, I guess I won't be getting a Roli Seaboard controller.waterstrum wrote: ↑Thu Sep 16, 2021 12:57 am
Yep.
So, if I don't have or use Reason, but, I have and use Ableton Live 11, this will cause the new DP 11 update to have issues? Just want to check in here before I update!...dewdman42 wrote: ↑Thu Sep 16, 2021 11:24 am The key to fixing the dp 11.01 crash is to delete the propellarheads application support folder. There is a rewire driver in there that dp 11.01 is not ignoring even though dp does not officially support rewire any longer.
If you ever run ableton live it may try to repopulate that application support folder again and would later cause dp to crash I guess. I think there is a way to disable ableton from doing that, google it.
But removing the propeller heads application support folder cured the problem. I don’t know what will happen if and when I try to use my reason plugin or ableton live again it might be that I will need to periodically delete this rewire malware.
Thanks, this did it. Thank God for other DP users…dewdman42 wrote: ↑Thu Sep 16, 2021 11:24 am The key to fixing the dp 11.01 crash is to delete the propellarheads application support folder. There is a rewire driver in there that dp 11.01 is not ignoring even though dp does not officially support rewire any longer.
Huh?
