+80 db is not enough? Are these people using mics or just shouting at the hard drive?
So fun searching for the simplest of Audio functions.....
Re: So fun searching for the simplest of Audio functions.....
First of all, that's hilarious. And yes, sometimes there are tracks with pitifully low levels (from clients or other sources, obviously).
I didn't know if that gain option would cause clipping-- if the sample's level exceeds zero.
My use of normalizing is always related to exporting soundbites as samples, tracks, mixes, MP3s, archives, etc.
I was looking at the text from the manual you posted above.
One reason why I got in the habit of doing this in DSP-Q. It has the Normalize To command which, technically I suppose, is not a Normalize function, but is at least a gain that avoids the possibility of clipping.stubbsonic wrote: ↑Thu Aug 12, 2021 10:39 pm I didn't know if that gain option would cause clipping-- if the sample's level exceeds zero.
Well there's another thing I was totally oblivious to. I've used Bite Gain but I've always selected it from the Audio Menu. Now I have another time saver. Thanks HC.
- waterstrum
I add my thanks for the little fader tip.
That will be a big time saver for me.
Much appreciated!
Much appreciated!
All is well
