So fun searching for the simplest of Audio functions.....
Re: So fun searching for the simplest of Audio functions.....
mikehalloran wrote: Thu Aug 12, 2021 1:53 pm Sometimes, that ol' pop up fader isn't nearly enough
+80 db is not enough? Are these people using mics or just shouting at the hard drive?
bayswater wrote: Thu Aug 12, 2021 4:05 pm
The fader only gives 16dB gain max.
bayswater wrote: Thu Aug 12, 2021 4:05 pm Are these people using mics or just shouting at the hard drive?
First of all, that's hilarious. And yes, sometimes there are tracks with pitifully low levels (from clients or other sources, obviously).
I didn't know if that gain option would cause clipping-- if the sample's level exceeds zero.
My use of normalizing is always related to exporting soundbites as samples, tracks, mixes, MP3s, archives, etc.
HCMarkus wrote: Thu Aug 12, 2021 4:43 pm
I was looking at the text from the manual you posted above.
bayswater wrote: Fri Aug 13, 2021 8:33 am
It is wrong. Just used the fader yesterday, confirmed +16 is all you getunless you merge and re-applyt. Sorry for inspiring confusion. :oops:
stubbsonic wrote: Thu Aug 12, 2021 10:39 pm I didn't know if that gain option would cause clipping-- if the sample's level exceeds zero.
One reason why I got in the habit of doing this in DSP-Q. It has the Normalize To command which, technically I suppose, is not a Normalize function, but is at least a gain that avoids the possibility of clipping.
Phil O
Post by Phil O »
HCMarkus wrote: Thu Aug 12, 2021 9:04 amif you click the Bite Gain Amount (shown + or - dB) in the lower left corner of each soundbite (shorter bites might require you to zoom in to reveal this number) you get a little fader you can drag up or down.
Well there's another thing I was totally oblivious to. I've used Bite Gain but I've always selected it from the Audio Menu. Now I have another time saver. Thanks HC. :D
waterstrum
Post by waterstrum »
I add my thanks for the little fader tip.
That will be a big time saver for me.
Much appreciated!
All is well
