DP does not remember key commands
ZailSi
Post by ZailSi »
Does anyone knows why all of a sudden DP won't remember any custom key commands??
Whenever I open a project all my custom key commands are gone and have to re-enter them again! Please help
MacPro 12 x 3.44Ghz 128RAM (x2) + VEPro7 - OS 10.14.6 - DP10.13
UA Apollo Twin MKII - MOTU 8PRE - ICON Platform M+
Re: DP does not remember key commands
I try to make it habit to save my Key Commands whenever I set them up, and whenever I make a change to them.
Unfortunately, the last time I did a big re-install, I hadn't saved in a while, so I did have to re-do them.
Maybe you could find them in a time-machine backup?
dix
Post by dix »
ZailSi wrote: Tue May 04, 2021 7:37 am Does anyone knows why all of a sudden DP won't remember any custom key commands??
Weird. I've never seen this. So the Commands revert to the defaults whenever you launch DP? ...i'm guessing someone here has seen this, but not me.
DP's Command Bindings are stored in User>Library>Preferences>com.motu.DigitalPerformer. I'd be curious if you see a Command Bindings doc there, and if so what the Modification Date is. That date and time should be the same as the last date and time you quit DP.
I don't know what the fix would be if the Command Bindings doc isn't updating, but a (sort of crappy) workaround would be what stubbsonic suggests: Exporting Commands before you quit DP and reimporting after you launch.
ronjams
Post by ronjams »
The idea is once you set up your key commands you then need to export them somewhere on your computer and then if somehow DP does not recognize your custom key commands you can then importThe file that you export it and that should work
Mac Studio M1 Max DIGITAL PERFORMER1248/8pre ESFalcon/kontakt/Unify & A LOT MORE GEAR
ZailSi
Post by ZailSi »
dix wrote: Tue May 04, 2021 11:35 amWeird. I've never seen this. So the Commands revert to the defaults whenever you launch DP? ...i'm guessing someone here has seen this, but not me.
This is exactly what's happening
dix wrote: Tue May 04, 2021 11:35 amDP's Command Bindings are stored in User>Library>Preferences>com.motu.DigitalPerformer. I'd be curious if you see a Command Bindings doc there, and if so what the Modification Date is. That date and time should be the same as the last date and time you quit DP.
I am not on that computer right now, but I will check later. thanks!
dix wrote: Tue May 04, 2021 11:35 amI don't know what the fix would be if the Command Bindings doc isn't updating, but a (sort of crappy) workaround would be what stubbsonic suggests: Exporting Commands before you quit DP and reimporting after you launch.
Right now is what I have to do each time I open DP... re-import the key bindings. I will also try to trash preferences later... see if I can fix it!
ZailSi
Post by ZailSi »
stubbsonic wrote: Tue May 04, 2021 8:53 am I try to make it habit to save my Key Commands whenever I set them up, and whenever I make a change to them.
I have the key bindings file, the issue is that I have to import it each time I open DP!
ZailSi
Post by ZailSi »
ronjams wrote: Tue May 04, 2021 2:49 pm The idea is once you set up your key commands you then need to export them somewhere on your computer and then if somehow DP does not recognize your custom key commands you can then importThe file that you export it and that should work
I know, but ideally I shouldn't be doing this each time I open DP...
ZailSi wrote: Thu May 06, 2021 7:45 am I have the key bindings file, the issue is that I have to import it each time I open DP!
I'm a little foggy on whether the key bindings are global or if they are project-specific. If they aren't saving with your file, or if they are part of your default New Project template, then there's probably something broken about DP, which might require a reinstall or a trashing of preferences.
At least you have your key bindings!
stubbsonic wrote: Thu May 06, 2021 4:49 pmI'm a little foggy on whether the key bindings are global or if they are project-specific.
Global.
ZailSi
Post by ZailSi »
Last night I moved the preferences file to the desktop (did not trash it), opened DP (it creates a new preferences file by default), imported the saved key bindings, restarted DP, and my custom key commands were still there. So it was a corrupt preferences issue.
Although by doing that it messed up a little bit DP studio settings (buses and prime milliseconds went back to the default settings) and some screens and session customization were gone too. As I am in the middle of a project working with a huge template, I restored the corrupt preferences file back in place as I didn't want to deal with changing those settings right now, but once I am done I'll trash the corrupt preferences file and start again.
