one-key shortcut to quantize in specific values
Greetings, everyone!
I'm a long time DP user. Currently on DP 9.52 with Mojave.
As everyone knows, it is easy to open the quantize window with the shortcut "command 0"
I wonder if anyone knows how can I program a one-key shortcut to quantize in eight notes, another one-key shortcut to quantize in sixteenths, etc. I'm pretty sure it cannot be done within DP's "Command" window.
Best regards,
Daniel Freiberg
Best regards,
Daniel Freiberg
- FMiguelez
Re: one-key shortcut to quantize in specific values
A macro app like Keyboard Maestro or QuicKeys can easily do that. I use QK for similar things, and I can't tell you how much time and redundant moves it's saved me.
[quote=FMiguelez post_id=579135 time=1606601177 user_id=1263]
[/quote]
Thanks a lot for the advice, FMiguelez !
Since I have never used Keyboard Maestro... will the Keyboard Maestro sequence be dependent on the look of my screen at the time of triggering the shortcut? In other words, will K Maestro be effective regardless of my DP windows configuration (consolidated window, Sequence window, Track window, etc) or display zoom level?
Greetings from NY!
Daniel
[/quote]
Greetings from NY!
Daniel
- FMiguelez
My pleasure.
It depends on the detail of how you set up the KM sequence, but typically it does matter where the windows open (their screen coordinates). At least most of my own sequences are dependent on where windows are placed in DP. However, since DP always remembers the location of the windows, it's never a problem and it's always reliable.
My favourite sequences are the ones I use to switch from Lines to Bars mode for CCs in the GE and to switch to/from a plethora of MIDI CCs and Reshape Tool modes.
It's so cool to press a key and just watch how things happen automatically as if by magic. I'm sure you'll keep finding workflows where you'll want to do them with KM. For DP and anything else... it can be addictive
Happy macro-making. Greetings from México City too!
You can do that in the Quantize window mini menu - save presets and then assign keys.
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
Thanks again, FMiguelez!
Will try to learn KMaestro! Saludos!
Daniel
[quote=FMiguelez post_id=579138 time=1606606821 user_id=1263]
My pleasure.
[/quote][quote=FREIMUZIC post_id=579137 time=1606605464 user_id=983]
[/quote]
Greetings from NY!
Daniel
[/quote]
Daniel
My pleasure.
[/quote]
Greetings from NY!
Daniel
[/quote]
Thanks so much for the advice, CharlzS!
I have saved the presets in the Quantize window mini menu, but how do you assign key-commands to trigger those presets on DP?
Regards,
Daniel
[quote=CharlzS post_id=579139 time=1606607784 user_id=59356]
[/quote]
Regards,
Daniel
[/quote]
In the Quantize mini menu - Set Preset Key Bindings. It will bring up the Commands window to assign keystrokes there.
Thanks again, CharlzS!
I am on DP 9.52. Sorry, but I can't find "Set Preset Key Bindings"
My Quantize mini menu only shows 2 options:
Save presets
Reveal presets in finder
...below these 2 options are the quantize presets I saved: q16.dpfxclip , q8.dpfxclip , etc
If I open the "Commands" window I only see
Export Key Bindings
Save Key Bindings
Revert to Default Key Bindings
Am I missing something?
Regards,
Daniel
[quote=CharlzS post_id=579142 time=1606610127 user_id=59356]
[/quote]
Save presets
Export Key Bindings
Save Key Bindings
Regards,
Daniel
[/quote]
Create and save the Quantize preset, then go back to the mini menu and select Set Preset Key Binding. This brings up the Commands Window. Search for Quantize. It should be there with the name you gave the preset in parentheses after the word Quantize.
Thanks for your advice, bayswater!
Here is an image of my Quantize mini menu. I wonder why it doesn't show "Set Preset Key Binding"...maybe I need to erase my preferences and start from a clean preference file?
Regards,
Daniel
[img]https://drive.google.com/file/d/18NdxEq ... sp=sharing[/img]
[quote=bayswater post_id=579144 time=1606612761 user_id=23311]
[/quote]
Regards,
Daniel
[/quote]
bayswater and FMiguelez,
I forgot to also include an image of my Commands window to show you that my quanytize presets are not showing there either...
[img]https://drive.google.com/file/d/1wgj4rf ... sp=sharing [/img]
Thanks again for your help !!
Daniel Freiberg
[quote=FREIMUZIC post_id=579145 time=1606613820 user_id=983]
Regards,
Daniel
[/quote]
[/quote]
Daniel Freiberg
Regards,
Daniel
[/quote]
[/quote]
I'm also in 9.52, and there's no "Set Preset Key Binding" in the mini menu.
Probably Keyboard Maestro is the way to go.
It's nice to know that DP10 may bring some new key bindings.
- waterstrum
Hey Daniel,
Thank you for opening this topic.
I use the quantize window frequently and had no idea that I could assign key commands to saved settings.
This is a very cool feature!
I'm running DP 10.13 and I just tested it.
Works great!
I had no idea that MOTU had added the implementation.
Maybe upgrading to 10.13 could solve the problem for you?
So far, for me, I've had no downside to using the current version.
That said, I know each system is very complex and you may have good reasons to stay on 9.52.
Works great!
All is well
In earlier versions without the mini menu option for key bindings try searching in the Commands window for whatever you named the preset on save. It might be in a section called Region Operation Presets towards the end. I think it's always been there as part of the presets feature, but DP10 just gives you an easier way to get there. I don't remember if 9.x has the Run Command window (cmd spacebar) which would bring up the preset without having to assign a key. Though maybe this is all new with DP10 - 9.x seems like forever ago. Someone threw an expander on my sense of time.
