Red Lines --how to get rid of them
fbkaiser
Post by fbkaiser »
Those red lines in a soundbite.
I've rtfm and I've searched this board and cant find the answer.
Thank you anybody,
Kaiser
Re: Red Lines --how to get rid of them
fbkaiser wrote:Those red lines in a soundbite.
Thank you anybody,
Kaiser
Page 390 "Soundbites That Cannot play"
Check under the word "red" in the index. Should be a simple fix.
Mike
fbkaiser
Post by fbkaiser »
Saw that page. That's not the answer. Checked the index too.
Thank you for responding.
fbkaiser wrote:Saw that page. That's not the answer. Checked the index too.
Are your soundbites playing? Playing correctly?
What is your global sample rate?
What is the sample rate of the soundbites?
MM
Last edited by MIDI Life Crisis on Wed Jan 25, 2006 8:43 am, edited 2 times in total.
fbkaiser
Post by fbkaiser »
Yes Correctly. All rates match.
Are we talking about red outlines? Or vertical lines periodically?
carrythebanner
Post by carrythebanner »
Check out p. 598.
oldguitars
Post by oldguitars »
Look up "clear soundbite tempo" The lines are telling you that the soundbite has a different tempo than the sequence.
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
musicarteca
Post by musicarteca »
If you want to get ride of them select the soundbite(s) with the red lines, and from the audio menu choose copy sequence tempo to soundbite.
Alex Rodriguez
Legato Productions
www.legatoproductions.com
fbkaiser
Post by fbkaiser »
Thanks guys, all of you.
"Clear sb tempo" erased the lines. (They were vertical lines, MM)
Question is: how did they get there in the first place?
musicarteca
If you import a soundbite, if you time compress/ expand it or change the tempo of the sequence, the soundbite will not have the same internal tempo as the sequence, this will be indicated with the red lines. If you clear the soundbite tempo or copy the sequence tempo into the sb, then they will disapear.
Alex Rodriguez
Legato Productions
fbkaiser
Post by fbkaiser »
Thanks, Alex. I understand.
Kaiser
fbkaiser wrote:Thanks guys, all of you.
So you couldn't find this in your manual? Any of this?
fbkaiser
Post by fbkaiser »
Mr. Steele,
As I said in my first post, no, I could not find it in my manual. Nor have I yet.
People have the option of not replying to questions that they feel is a waste their time, I believe?
fbkaiser
Spikey Horse
Post by Spikey Horse »
fbkaiser wrote: People have the option of not replying to questions that they feel is a waste their time, I believe?
fbkaiser
Yes and you have the option of providing enough info just to reassure eveyone helping you that you are not using a pirated copy.
It's a two way street.
(and saying what version you're using etc at the start would help, too)
By having to rely on someone spelling it out in a post here when someone had ALREADY given you the SAME answer by way of a page number in the manual you end up looking like a pirate.
For example you could have said "yes, I read paragraph called '............' on page 598 but I still don't get it".
It doesn't require any great effort.
