Red Lines --how to get rid of them
Those red lines in a soundbite.
I've rtfm and I've searched this board and cant find the answer.
Thank you anybody,
Kaiser
Thank you anybody,
Kaiser
Re: Red Lines --how to get rid of them
Page 390 "Soundbites That Cannot play"fbkaiser wrote:Those red lines in a soundbite.
Thank you anybody,
Kaiser
Check under the word "red" in the index. Should be a simple fix.
Mike
Are your soundbites playing? Playing correctly?fbkaiser wrote:Saw that page. That's not the answer. Checked the index too.
Thank you for responding.
What is your global sample rate?
What is the sample rate of the soundbites?
MM
Last edited by MIDI Life Crisis on Wed Jan 25, 2006 8:43 am, edited 2 times in total.
Are we talking about red outlines? Or vertical lines periodically?
Look up "clear soundbite tempo" The lines are telling you that the soundbite has a different tempo than the sequence.
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
- musicarteca
- musicarteca
If you import a soundbite, if you time compress/ expand it or change the tempo of the sequence, the soundbite will not have the same internal tempo as the sequence, this will be indicated with the red lines. If you clear the soundbite tempo or copy the sequence tempo into the sb, then they will disapear.
So you couldn't find this in your manual? Any of this?fbkaiser wrote:Thanks guys, all of you.
"Clear sb tempo" erased the lines. (They were vertical lines, MM)
Question is: how did they get there in the first place?
- Spikey Horse
Yes and you have the option of providing enough info just to reassure eveyone helping you that you are not using a pirated copy.fbkaiser wrote: People have the option of not replying to questions that they feel is a waste their time, I believe?
fbkaiser
It's a two way street.
(and saying what version you're using etc at the start would help, too)
By having to rely on someone spelling it out in a post here when someone had ALREADY given you the SAME answer by way of a page number in the manual you end up looking like a pirate.
For example you could have said "yes, I read paragraph called '............' on page 598 but I still don't get it".
It doesn't require any great effort.
