Sending DP files via net for Collabs..........
TRUN
Post by TRUN »
Hello guys... anyone want to send some direction on the best way to send DP files to a writing partner/musician for collaboration via the web.....thanks in advance for the help.....
chucks
Post by chucks »
www.yousendit.com - someone else on this board recommended it a while back and it worked great - fast and easy. I also tried using iDisk and it was incredibly slow, basically unuseable.
kwiz
Post by kwiz »
Yeah, I use an idisk and it is slow but it works.
You send it is cool but I'm always afraid of public servers.
The last thing I need is someone intercepting my files.....just my personal paranoia :lol:
Great family and friends!
F. Douglas
chrispick
Post by chrispick »
I've been using streamload.com and setting up password-protected public folders. It's been plenty secure enough for me.
kofasetic
Post by kofasetic »
TRUN
Post by TRUN »
and what do you guys send? stereo AIFF, stereo SDII, MP3, digital performer document? let me know......tried sending a stereo SDII and it would not open......I'm sure I'm doing something wrong.....
carrythebanner
Post by carrythebanner »
It's a good chance that somewhere along the lines of transmission that your files will end up passing through a PC or UNIX system, so if you're sending Mac-specific files like DP projects and SDII audio files you should probably ZIP or StuffIt them so they don't lose their resource forks.
TRUN
Post by TRUN »
and how do I Zip and/or Stuff files? thanks so much for the direction..........
chrispick
Post by chrispick »
TRUN wrote:and how do I Zip and/or Stuff files? thanks so much for the direction..........
If you're on a Mac with OSX...
...Control-click the file(s) or folder(s) you want to compress, then select "Create archive" from the menu that appears. This will ZIP them up.
The recipient need only double-click on this newly-created ZIP file, and it'll extract automatically.
BTW: If you have a multi-button mouse, you can use right-click rather than control-click. Works the same, only one-handed.
TRUN
Post by TRUN »
great!!! thanks chrispick... thanks so much guys for the help.......
Tim
Post by Tim »
What app does that use?
Is there a way to set prefs for that method?
I use Stuffit and set prefs to No Compression.
chrispick
Post by chrispick »
I don't know. It's part of the OS, but I assume they license the algorithm from someone.
If you run an "get info" on these ZIP files, they're set to open using BOMArchiveHelper (whatever that is). And they'll open via StuffIt too.
Anyway, I've found that when I zip, then unzip using this method the pre-zip and post-zip files match in size down to the byte. So, it's lossless -- seemingly. But, the ZIP file itself appears smaller -- until you run a "Get Info" and see it's the same approximate size as it's unzipped contents (although not to the exact byte).
Hmm...
Maybe a techie can step in with some better science here than I can muster?
Doesn't seem to be. There's minimal help reference supplied for this function.
lsdd
Post by lsdd »
You know what.......I know this sounds stupid...And slow......And expensive......But to insure against any incompatibilties or "mangles" or interceptions ( I'm sure there are loads of folks out there who are smarter than me about computers who would love to steal my stuff)
Just mail a project CD/DVD? Fed EX?
AND/Or hound MOTU about ditching SD2?
I know it's very frusterating..
xxd
G5 dual 1.8, Leopard/ DP4.6.1 / 2408mk3 / Mach5| / Korg ES1/Korg Ms2000
chrispick
Post by chrispick »
lsdd wrote:You know what.......I know this sounds stupid...And slow......And expensive......But to insure against any incompatibilties or "mangles" or interceptions ( I'm sure there are loads of folks out there who are smarter than me about computers who would love to steal my stuff)
xxd
I think password-protected FTPs are the way to go, FWIW.
azusa749a
Post by azusa749a »
There is an article about this and more in the February issue of Recording Magazine.
I did't have time to read the whole thing at Borden's rack.
Basically is some guys use DP to work through internet.
