Sending DP files via net for Collabs..........
Hello guys... anyone want to send some direction on the best way to send DP files to a writing partner/musician for collaboration via the web.....thanks in advance for the help.....
www.yousendit.com - someone else on this board recommended it a while back and it worked great - fast and easy. I also tried using iDisk and it was incredibly slow, basically unuseable.
Yeah, I use an idisk and it is slow but it works.
You send it is cool but I'm always afraid of public servers.
The last thing I need is someone intercepting my files.....just my personal paranoia
Great family and friends!
F. Douglas
F. Douglas
It's a good chance that somewhere along the lines of transmission that your files will end up passing through a PC or UNIX system, so if you're sending Mac-specific files like DP projects and SDII audio files you should probably ZIP or StuffIt them so they don't lose their resource forks.
If you're on a Mac with OSX...TRUN wrote:and how do I Zip and/or Stuff files? thanks so much for the direction..........
...Control-click the file(s) or folder(s) you want to compress, then select "Create archive" from the menu that appears. This will ZIP them up.
The recipient need only double-click on this newly-created ZIP file, and it'll extract automatically.
BTW: If you have a multi-button mouse, you can use right-click rather than control-click. Works the same, only one-handed.
I don't know. It's part of the OS, but I assume they license the algorithm from someone.Tim wrote:What app does that use?chrispick wrote:
If you run an "get info" on these ZIP files, they're set to open using BOMArchiveHelper (whatever that is). And they'll open via StuffIt too.
Anyway, I've found that when I zip, then unzip using this method the pre-zip and post-zip files match in size down to the byte. So, it's lossless -- seemingly. But, the ZIP file itself appears smaller -- until you run a "Get Info" and see it's the same approximate size as it's unzipped contents (although not to the exact byte).
Hmm...
Maybe a techie can step in with some better science here than I can muster?
Doesn't seem to be. There's minimal help reference supplied for this function.Is there a way to set prefs for that method?
You know what.......I know this sounds stupid...And slow......And expensive......But to insure against any incompatibilties or "mangles" or interceptions ( I'm sure there are loads of folks out there who are smarter than me about computers who would love to steal my stuff)
Just mail a project CD/DVD? Fed EX?
AND/Or hound MOTU about ditching SD2?
I know it's very frusterating..
xxd
xxd
G5 dual 1.8, Leopard/ DP4.6.1 / 2408mk3 / Mach5| / Korg ES1/Korg Ms2000
I think password-protected FTPs are the way to go, FWIW.lsdd wrote:You know what.......I know this sounds stupid...And slow......And expensive......But to insure against any incompatibilties or "mangles" or interceptions ( I'm sure there are loads of folks out there who are smarter than me about computers who would love to steal my stuff)
xxd
