DP crashes when closing Waves Electric 88
Hi.
I've got a track that's working find except for one thing.
When I try to close the Waves Electric 88 window, or delete the track, the program crashes.
As long as I leave the plugin open, all is well.
Oops. Just started crashing when I quit, too.
Any ideas?
Thanks.
Any ideas?
Thanks.
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
L3 Cache: 12 MB
Re: DP crashes when closing Waves Electric 88
Similar rig, Mojave, but DP10.11 not a problem here.
This wasn't a problem till yesterday.
Also noticed it crashes when I try to change the buffer.
So maybe it's not connected to the Waves plugin.
I'm going to try loading DP without plugin turned on and see if I can just delete that track and see what happens.
L3 Cache: 12 MB
L3 Cache: 12 MB
Re: DP crashes when closing Plugins
Update.
I opened DP in safe mode and deleted the "offensive" plugin.
Then opened DP again.
All seemed okay for a little while.
But now it freezes with other plugins. Usually freezes when I close the plugin window.
L3 Cache: 12 MB
L3 Cache: 12 MB
Re: DP crashes when closing Waves Plugins
Additional info.
Tried using a waves plugin in another file. It closed without crashing.
L3 Cache: 12 MB
L3 Cache: 12 MB
Have you tried Loading the problem Project file into anew DP Project?
Yes.
Same problem.
Now I' m working on it and just leaving the waves plugin window open. Everything is ok, but when I quit DP it freezes again.
Same problem.
L3 Cache: 12 MB
L3 Cache: 12 MB
I found some info on the Motu site and followed their suggestions.
I dumped the com.motu.DigitalPerformer.plist and the folder com.motu.MotuAudioSystem
I no longer have the Waves problem and it looked like all was well.
However, whenever I quit DP it crashes. So I seem to have narrowed it down... I guess.
L3 Cache: 12 MB
L3 Cache: 12 MB
Solved.
Was on the phone for a long time with Waves tech support.
Turns out the Version 11 plugins were the problem. Apparently I have to upgrade to DP 10 to use them. Crap!
L3 Cache: 12 MB
L3 Cache: 12 MB
Thanks for the info. Will undoubtedly help someone.
I trust Waves will give you v10, too?
You're welcome. Hope it helps.
L3 Cache: 12 MB
L3 Cache: 12 MB
