Trombone slide
- Primary DAW OS: Windows
Trombone slide
I am trying to make a MIDI trombone voice slide up a perfect fourth. The pitch bend only goes a major second. I can't figure out how to make portamento work. Can any of you kind folks point me in the right direction with this?
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Re: Trombone slide
Most statins will allow a range for pitch bend. Two steps is usually the default but you might look at your VI/synth/whatever to program the range for pitch bend.
Re: Trombone slide
Thanks for your reply. I’ve searched my Garritan manual and can’t find the way to do this. I will keep looking, though. If anyone on the board here is a Garritan user, perhaps they could help me.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Re: Trombone slide
Hey Rick, I have GPO and you can set pitch bend.
https://usermanuals.garritan.com/ARIAPl ... tch%20bend
You click on the slot with the instrument (the menu item DEF (define pitch bend). Set and slide your heart away.
Re: Trombone slide
Thanks so much. It never occurred to me to set the pitch bend range in the Aria player. That was exactly the information I needed.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Re: Trombone slide
I know. lol Happy to help.Rick Averill wrote:Thanks so much. It never occurred to me to set the pitch bend range in the Aria player. That was exactly the information I needed.
- bkshepard
Re: Trombone slide
On a practical note (pun intended), the maximum a trombone can slide is an augmented-fourth (7th position to 1st position). Depending on your starting note (slide position), a major 2nd might be all the room there is for the slide.
-Brian
Re: Trombone slide
Party pooper! lol
- mhschmieder
Re: Trombone slide
Yep, I was about to add that technical limitation of the actual instrument.
I have Garritan stuff but never use it so didn't get too familiar with its pitch bend ranges and portamento handling. I use Sample Modeling's Trombone, and the user manual is excellent in describing the preferred approaches to achieving different intervals; I think Vienna Symphonic Library also carefully documents the extent of portamento vs. glissando vs. other articulation categories.
I hope you get good results from GPO with the revised pitch bend range. Sample Modeling takes a unique approach and it's a bit cumbersome to achieve; I pretty much have to manually edit after-the-fact, analyze the ratios of note velocity, dynamics, and other factors, and then figure out the length of the "special key" and its velocity, to achieve realistic portamento/slide.
Re: Trombone slide
Once MIDI Life Crisis pointed me in the right direction, I had no problem getting the sound I wanted.
I once had a very good trombonist playing on a chart I had written and he told me that a gliss I had written didn’t lay within the slide, but that he could fake it. He did and it sounded perfect.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
- bkshepard
Re: Trombone slide
Yeah, players have developed all kinds of tricks to make up for composer/orchestrator mistakes. I'm lookin' at you Béla Bartók!
-Brian
