Trombone slide
Rick Averill
Trombone slide
Post by Rick Averill »
I am trying to make a MIDI trombone voice slide up a perfect fourth. The pitch bend only goes a major second. I can't figure out how to make portamento work. Can any of you kind folks point me in the right direction with this?
Rick Averill
DP 10, Mac Mojave
Re: Trombone slide
Most statins will allow a range for pitch bend. Two steps is usually the default but you might look at your VI/synth/whatever to program the range for pitch bend.
Rick Averill
Re: Trombone slide
Thanks for your reply. I’ve searched my Garritan manual and can’t find the way to do this. I will keep looking, though. If anyone on the board here is a Garritan user, perhaps they could help me.
Rick Averill
DP 10, Mac Mojave
Re: Trombone slide
Hey Rick, I have GPO and you can set pitch bend.
https://usermanuals.garritan.com/ARIAPl ... tch%20bend
You click on the slot with the instrument (the menu item DEF (define pitch bend). Set and slide your heart away. ;)
Rick Averill
Re: Trombone slide
Thanks so much. It never occurred to me to set the pitch bend range in the Aria player. That was exactly the information I needed.
Rick Averill
DP 10, Mac Mojave
Re: Trombone slide
Rick Averill wrote:Thanks so much. It never occurred to me to set the pitch bend range in the Aria player. That was exactly the information I needed.
I know. lol Happy to help. :unicorn:
bkshepard
Re: Trombone slide
Post by bkshepard »
On a practical note (pun intended), the maximum a trombone can slide is an augmented-fourth (7th position to 1st position). Depending on your starting note (slide position), a major 2nd might be all the room there is for the slide.
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
Re: Trombone slide
Party pooper! lol
mhschmieder
Re: Trombone slide
Post by mhschmieder »
Yep, I was about to add that technical limitation of the actual instrument. :-)
I have Garritan stuff but never use it so didn't get too familiar with its pitch bend ranges and portamento handling. I use Sample Modeling's Trombone, and the user manual is excellent in describing the preferred approaches to achieving different intervals; I think Vienna Symphonic Library also carefully documents the extent of portamento vs. glissando vs. other articulation categories.
I hope you get good results from GPO with the revised pitch bend range. Sample Modeling takes a unique approach and it's a bit cumbersome to achieve; I pretty much have to manually edit after-the-fact, analyze the ratios of note velocity, dynamics, and other factors, and then figure out the length of the "special key" and its velocity, to achieve realistic portamento/slide.
Rick Averill
Re: Trombone slide
Once MIDI Life Crisis pointed me in the right direction, I had no problem getting the sound I wanted.
I once had a very good trombonist playing on a chart I had written and he told me that a gliss I had written didn’t lay within the slide, but that he could fake it. He did and it sounded perfect.
Rick Averill
DP 10, Mac Mojave
bkshepard
Re: Trombone slide
Post by bkshepard »
Yeah, players have developed all kinds of tricks to make up for composer/orchestrator mistakes. I'm lookin' at you Béla Bartók! :)
-Brian
