SOLVED !Wierd Clock Problem/ MicroBook/MKIII Hybrid
apanacci
Post by apanacci »
Hey guys, thought I would post before I send a support ticket to Motu. In my Hardware Driver setup I have my Hybrid MKIII and MicroBookII locked together.The MKIII is the clock. I have my Motif 6 plugged into the MicroBook in line 1 and 2.All my inputs are used up in the MKIII so thats why I hooked into the MicrBook. I have had this setup for awhile now. Worked fine for me. If I needed to record the Motif it was there. I have not used it for awhile so now I am on DP 10.11 and I tried it and I am now having clock issues between the units. I then hooked a mic to the MicroBook and it had the same problem. I tried the same setup in Audio Desk and it worked fine, both Mic and Line. I went back and made the MicroBook the clock and it worked for awhile and then the clock issues again.Does anything stick out ? Thanks, a long winded one !
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
apanacci
Re: Wierd Clock Problem/ MicroBook/MKIII Hybrid
Post by apanacci »
I did load the latest Audio driver a few months ago. I am on High Sierra. Maybe I need to dial back to the version before the latest, will give that a try.
apanacci
Post by apanacci »
Not the MOTU Audio system. Going to reinstall DP9 on my 3rd drive and try that.
apanacci
Post by apanacci »
Tried DP 9.52, older Motu Audio System. Still does not work. But Audio Desk still works with my setup. DP9 and 10 does not. Strange, I will contact MOTU.
apanacci
Post by apanacci »
I solved it ! I chose SPDIF for the clock and it worked! No more clock issues.
philbrown
Re: SOLVED !Wierd Clock Problem/ MicroBook/MKIII Hybrid
Post by philbrown »
Thanks for posting your solution and marking it solved in the subject line. A courtesy that's appreciated "across the board'. Sorry, couldn't pass that one up.
apanacci
Post by apanacci »
I thought everyone was staying away because of Covid 19! We all have are own setups. Thanks for the reply Phil. I tried many things and it feels great to find a solution. That,s why I really value this forum. So many people are helpful and knowledgeable.
