Anyone using Polar?
philbrown
Anyone using Polar?
Post by philbrown »
I'm curious if anyone is using Polar and how you are utilizing it. I found this article which was a nice refresher:
https://www.soundonsound.com/techniques ... comp-tools
CharlzS
Re: Anyone using Polar?
Post by CharlzS »
Comping and Polar were covered in the Webinar on Thursday, so when they post the session there will be some good DP10 video with practical applications. There are also some good videos on YouTube. I had mostly forgotten Polar was there.
The Thursday webinar went over Polar. I’d never paid attention to it before.
I do what I need just recording with memory cycle on, and then comping the takes. I've tried Polar a few times since V 4, but never found it intuitive. Seemed like a clever solution looking for a problem.
One thing about POLAR is that, like Chunks, BTD and plug-ins, it uses RAM.
This is useful to remember the next time one of those "no one needs more than xGB RAM" threads shows up again.
mikehalloran wrote:One thing about POLAR is that, like Chunks, BTD and plug-ins, it uses RAM.
That's easy for you to say with 128G.
EMRR
Post by EMRR »
Once when I had (apparently) erroneously used Songs to create a playlist of Chunks for a musical theater backing, I found that Polar was the only way I could capture a 'bounce' of the mix within DP for the entire show.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
mesayre
Post by mesayre »
I sometimes like using Polar for things like guitar textures.
I will say, it would be immensely more useful if you could put inserts into the record path like a tape loop, or if DP would allow you to route the outs back to the ins. I doubt that'll happen though. Ah well
Mike
philbrown
Post by philbrown »
bayswater wrote:I do what I need just recording with memory cycle on, and then comping the takes. I've tried Polar a few times since V 4, but never found it intuitive. Seemed like a clever solution looking for a problem.
Stated way better than I could have.
rixax@vex.net
Post by rixax@vex.net »
First I used Polar live with MIDI triggering samples. I created a set of remembered times and then switched to them manually to create phasing loops of different instruments and soloed over them. Now, broadcasting on Twitch (as soundpilot) I use a headset and create phasing loops 9/8, 6/4, 14/8 4/4/ with acoustic instruments and solo on a vibraphone. No live audience so I don't monitor in the air. I just wish that I could assign remembered times to MIDI notes or key commands.
Rick Sacks
Toronto
rixax@rixax.com
musictosh
Post by musictosh »
I am a percussionist, and use it to make percussion loops in projects. I have had people sending me a mix that needs percussion to "liven" things up. Thanks to Polar I could send off 10 8 bar tracks within 30 minutes.
I am currently working on Logic simply because a lot of my collaborators do, but I miss Polar.
edised
Post by edised »
I use it all the time to record stack of backing vocals or complex guitar arpeggios
It's a great tool and for me the one tool I couldn't be without.
