Info Box Incorrect?
Info Box Incorrect?
Someone sent me 24 recorded tracks to mix. I dragged them into the TO, switched to the SE, selected all, and dragged the first downbeat in the kick drum track to a logical starting point, in this case 5/1/1. When dragging, an info box pops up (example below). It appears to report how many soundbites are being moved. But the number it reports is actually the number displayed on the edit screen. You can verify this by zooming in and out.
I checked what it was doing, and saw all the selected soundbites are moved correctly.
Am I missing something? Why would DP report the number of object being moved that are visible, rather than the number being moved?
Phil O
Re: Info Box Incorrect?
Post by Phil O »
Definitely report this one. Sounds like something that got missed in beta testing to me.
I certainly will if at least one person can repeat it. There are so many things like this now that happen on some setups and not others. Odd that no one else has noticed it if it's real.
Phil O
Post by Phil O »
I'll see if I can duplicate it
Phil O
Post by Phil O »
OK. I cannot verify that it IS the number of soundbites showing in the window, but...
The number indicated does change depending on how many soundbites are visible - sometimes. I'm not able to see the pattern, but there's definitely something wonky going on.
OK, thanks. I didn't verify the reported soundbite count either. It doesn't really matter if it counts the number visible correctly if that has no bearing on the edit operation.
I'll do a tech link.
MOTU acknowledges this as a bug.
Phil O
Post by Phil O »
I saw that last night for the first time. At last, something I can ignore.
jggorman
Post by jggorman »
Speaking of ignoring, Mike, I've been trying to get you to reply to me for over two weeks. Are you getting my messages?
Eat Life or it will Eat You. Survival is insufficient.
Mac Pro 2009 (5,1 fw) • 3.46 GHz 12-Core • 96gb ram • 500gb m.2 SSD on PCIe • 7TB Internal Storage • GTX-1080 Hybrid • OS X 10.16.3 (and staying there)
