MIDI from audio
tbm
MIDI from audio
Post by tbm »
Is there a way to create MIDI from an audio track. I want to create a MIDI track to trigger a synth bass from my audio bass track and blend the two in a mix.
thanks
DP 10.1, Imac i7, 4.2Ghz, 40GB Ram, Apollo X8+ Quad pci card, 1 terabyte SSD work drive.
http://thebluemusic.com
Re: MIDI from audio
YMMV. I've had limited success with this. It helps if the audio track is very clean, dry, simple and monophonic:
viewtopic.php?f=1&t=38433
Re: MIDI from audio
Page 944 these days.
CharlzS
Re: MIDI from audio
Post by CharlzS »
Something to check out if you'll be doing this often: https://www.jamorigin.com/
You can blend in real time and they have a version specifically for bass with free trials.
Re: MIDI from audio
cuttime wrote:Page 944 these days.
Oh no! Not :rtfmmad: ?!?!?!
Phil O
Re: MIDI from audio
Post by Phil O »
What's interesting is I don't know if that was a joke.
Phil O
Re: MIDI from audio
Post by Phil O »
I haven't used it in a while, but Melodyne does a pretty good job of this.
Re: MIDI from audio
That's sorta' what I was a thinking, too. The proverbial haystack keeps getting bigger. That said, the searchable .pdf manual does make the task less daunting than it used to be...
Re: MIDI from audio
Not a joke. The thread I originally linked to gave a different page number, and I did it to avoid confusion,
Phil O
Re: MIDI from audio
Post by Phil O »
The joke is on me. I mistakenly went to page 994 instead of page 944. Page 994 is blank. :oops:
Dyslexia sucks.
Re: MIDI from audio
I tend to use the manual dexterity method, being essentially a keys player these days. I don't say that flippantly (or don't I?... lol). But if the music is accessible within your technique, it might be a lot quicker and more accurate just entering the notes from a controller.
Ef, the offing manual. Ef it! :rofl:
Re: MIDI from audio
MIDI Life Crisis wrote:I tend to use the manual dexterity method
ISWYDT
Re: MIDI from audio
ISWYDT
OMG! I didn't notice. I'm sooooo embarrassed. Think anyone else saw it? :shock:
mhschmieder
Re: MIDI from audio
Post by mhschmieder »
Melodyne can be quite successful at this, depending on the source.
Where it breaks down the worst, is when you've recorded something from a keyboard ROMpler with the master effects and reverb at default settings, which invariably are quite high. This causes massive confusion in distinguishing unique notes, as reverb tails can get discretized to lots of individual staccato hits.
zandurian
Re: MIDI from audio
Post by zandurian »
Done this successfully with Melodyne as well...
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
