DP10 Crashes while in Sequence Editor
Chris T
Post by Chris T »
I'm running DP10 (fully updated) in OS14.6 on a Mac Pro. I'm getting regular crashes while trying to edit audio tracks in the Sequence editor. This often happens when I move or cut/slice audio files, or attempt to add a cross-fade between two neighboring audio files.
Any obvious answers to this issue? I run dozens of plugins, verbs, VIs etc within DP, but this happens just as often when every VI track is disabled and perhaps only a few audio tracks are enabled / playing.
CT
Main SYS: 12-Core New Mac Pro (Dec 2013), 64GB RAM, OS10.10, Apollo Quad Interface, 3xSSD work/sound drives in TB Enclosure, UAD Plugs, DP, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2nd SYS: Intel 8-Core Mac Pro (2007), 28GB RAM, OS10.7, MOTU PCI 424, 2408 interfaces (4), DP8.07, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2 Mac Minis (2011): Dual Quad, 16GB RAM running VE Pro, various libraries in Kontakt, G-Player, UVI.
mrgkeys
Re: DP10 Crashes while in Sequence Editor
Post by mrgkeys »
I've had similar issues in other version of DP, so I don't know if these tips help you or not with DP10, but here goes. Different fixes each time from edge editing and drawing fades. First, if you have a LOT of fades, aka multitrack drums that are cut and quantized, merge them into one audio file. Fixed my problem in DP 8 like this.. the second is to generate a new ColorSync profile in the Display Control Panel. I had a corrupted one (don't ask me how it happened, I don't know) but as soon as I made a new one, DP got super spiffy and the crashes stopped in DP 9. If you'd like to know how to turn back on the OS crash reporter so you can see the Crash Log and maybe troubleshoot an affected plugin, drop me a PM and I'll forward a terminal command.
[quote="mrgkeys".. the second is to generate a new ColorSync profile in the Display Control Panel. I had a corrupted one (don't ask me how it happened, I don't know) but as soon as I made a new one, DP got super spiffy and the crashes stopped in DP 9.[/quote]Apparently, it's an Apple issue and not a DP bug as far as anyone knows. There are some other threads on this. Selecting one of the other ColorSync profiles does the trick, also.
Chris T
Post by Chris T »
Thanks guys. by "Color Synch Profile" do you mean PReferences / Display / Themes ? Any particular one work better for you? I'm currently on "Alloy".
This would be System Preferences > Displays > Colour where a list of profiles appears.
