Hi All,
Brand new to the world of MOTU after purchasing a used 2408 mk3 and PCI 424 last week. Everything is working well and I am successfully recording audio into my Windows 7 system, however I can only record into 2 inputs at once.
When selecting the driver within my DAW (have tried multiple), I can only select either 1 & 2, 3 & 4, 5 & 6 or 7 & 8, rather than being able to use all 8 analog inputs simultaneously. All analog inputs have been activated in the PCI Audio Console.
Any help would be greatly appreciated!
Using all inputs simultaneously with 2408 mk3
- terrybritton
- Primary DAW OS: Windows
Re: Using all inputs simultaneously with 2408 mk3
I assume you have the Bundles page setup correctly. (SHIFT-U)
Do you have Multi Record selected under the Studio menu?
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Thanks for your response Terry!terrybritton wrote:I assume you have the Bundles page setup correctly. (SHIFT-U)
Terry
However, you are going to have to be a bit more specific as I am a complete noob.
Where do I find the Bundles page and the Studio menu? Is it within my DAW (Ableton) or within one of the MOTU programs?
Thanks,
Callum
- terrybritton
Oh, sorry Callum! I'm so used to Digital Performer questions here that I completely spaced that you might be using a different DAW!
In Ableton it is in the preferences, I believe, under the audio tab. Not sure where you turn on multi-record. Sorry - that is an ableton live forum question!
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Mmm I'm fairly positive it's not a daw related issue unfortunately, more likely driver or OS. I might try and get in touch with motu customer support. Thanks anyway!
Again, it’s even a DP issue as long as I can rememb... SQUIRREL!
