Can't import a mono file
Please help! I assume this is possible but I for the life of me can't figure it out.
I've got a stereo wave file that came out of pro tools, I deinterleaved the file so now I have file.L.wave and file.R.wav. When I pull one of the files into DP, it always pulls both and creates a single stereo file. How can I separate these two files? I'm sure I could rename them and that would probably work but is there a preference or something I'm missing?
Re: Can't import a mono file
You meant that you created a mono track in DP first and then dragged the file into it or are you attempting to import it as a soundbite?
Mac Pro 3.33 Six Core & MacMini 3.2 GHz i7 RAM 64 GB w/10.10.5 & 13.6.1 | MOTU DP9.5 & 11.3 | Apogee Duet & Ensemble Firewire | UAD Apollo Twin MKII | KRK V8 (original)| MOTU MIDI ExpressXT | MOTU micro lite | Roland XV3080 | Korg TR-Rack(Trinity) | EMU EIV XT Ultra | Clavia Nord Lead 2X | Access Virus TI Snow | Korg M3 | Fostex D-5 | Plugins: Boz Digital Labs, FabFilter, Korg, KV331Audio, MOTU, Metric Halo, NI, Roland Cloud, Sonarworks, UAD, Voxengo, Waves, iZotope, u-he...
I'm trying to import it as a soundbite. If I drag it from the finder into the soundbite window in DP, it shows up as a stereo file not just the one mono file (left or right).
- bkshepard
Haven't had to do this in awhile, but I believe you have to remove the .L and .R from the file names before you import. So if you files are something like filename.L.wav and filename.R.wav, rename them something like filename_left.wav and filename_right.wav. That should do the trick.
-Brian
Mac M1 Ultra 20-core, OS 15.5, 128 GB RAM, DP 11.3.4, UA Apollo x6
If you have a batch of them, you can use a file renamer. For Mac I use one called NameChanger which works well.
DP sees the .L and knows to look for a .R file. It's trying to do you a favor. To my knowledge there isn't a way to change this behavior. So you use the workaround suggested and change the name.
thanks everyone.
You can also do this in Finder but I forget the procedure. There’s a very old post somewhere where I explained how.stubbsonic wrote:If you have a batch of them, you can use a file renamer. For Mac I use one called NameChanger which works well...
if it's just a matter of renaming a bunch of files, you could do it like this:mikehalloran wrote:You can also do this in Finder but I forget the procedure. There’s a very old post somewhere where I explained how.stubbsonic wrote:If you have a batch of them, you can use a file renamer. For Mac I use one called NameChanger which works well...
create a new Folder - maybe call it "Lefts" and drag all of your .L files in there. Now select all of those files within the folder and Right-Click and you'll see "Rename X Items" (where "X" indicates the number of files you are renaming. When that window opens, select "Replace Text" and next to "Find:" type ".L" and next to "Replace With" type nothing....just hit RETURN. All of your files should now have no ".L" as extensions.
Repeat entire procedure with ".R" files
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
Select the files and a Rename command appears in the Finder>File menu. If you select more than one file, a window with a number of rename types and options appears. Using the "replace text" option lets you rename filename suffixes.mikehalloran wrote:You can also do this in Finder but I forget the procedure. There’s a very old post somewhere where I explained how.
Hello,
You only need to delete the period, the "L" can stay for reference.
It's the ear, not the gear!
MacPro 2.66 gHz 12 core (dp 10.01) - Lynx Aurora16 - OS 10.12.6/WaveArts/TruePianos - Legend 32ch console - G16 Fostex
(2) MacPro 2.66 gHz 12 core (DP 9.5) OS 10.12 - 24 I/O - 2408 mk2 - Da7- (PT 12) - 8 trk MCI
MacPro 2.66 gHz 12 core - OSX 10.12 - Genesys Black - Lynx Aurora16 - waves - Oxford - McDSP - 16 trk Otari - analog sweetness
Well now, that's a handy thing Don! Thanks for posting.Don T wrote:Hello,
- Helen
Sweet! Thank you for the lesson in elegant simplicity.Don T wrote:Hello,
Mac Pro Rack 7,1 3.2 Ghz 16-core, OS 12.7.4, 192GB ram
MOTU 828es, DP 11.31, Altiverb, Kontakt 7, VEPro
This job is fun, this job is fun, this job is fun....
