DP 10 working with dual screens on Sierra?
If I run DP with "Displays have separate spaces" checked in Mission Control, DP display responds normally. However the consolidated window will not stretch across the two screens.
If I run with "Displays have separate spaces" unchecked, the consolidated window will stretch across the two screens, but DP display response speed decreases with track count. (about 1 second to show any changes if running 100 empty mono tracks).
Is anybody successfully running DP 10 using the consolidated window across 2 screens?
2 x 2.8 Quad core Intel Xeon, 10.10.5, 16GB, DP8.07, 828mkII, Ensemble, Waves, Sonnox, iZotope, MachFive3, Kontakt, MC Control, MC Mix, VE Pro5.
Re: DP 10 working with dual screens on Sierra?
I did a little test on a project with about 35 MIDI tracks (Displays have separate spaces unchecked) and can confirm a slow down in redraw response time.
Interesting, it's only a bug when the consolidated window stretches across two screens.
Doesn't happen with separate windows in both screens etc.
Definitely write up a tech support on it.
ps - I stretched it across three screens. 30" Apple Cinema (center) and a Viewsoniq 26" (I think) on each side.
Thanks MLC and Michael for your replies!
I reported that to motu last week. Please do the same if you haven't. Am hoping for resolve.
Hi Labman, I just got of the phone with Motu. They are aware of the issue and hoping to fix the bug soon.
