Mr Clifford wrote:It's definitely the MAS Altiverb.
Have you reported to AudioEase?rk21 wrote:I might have been celebrating too soon...only MAS version is giving me issues.
No, not yet. But that's a good point.Have you reported to AudioEase?
Hi,
Thanks.
This has to do with macOS 10.13 and the AFP hard disk formatting. The only two solutions are: 1) wait for our fix, 2) revert to an earlier macOS (10.12 or lower). Both options are unfortunately not very pleasant, sorry.
Using VST temporarily could work too, but indeed opening older projects is not going to work this way.
I have filed this as a bug. We will try to fix this in the next update, but at this moment I dare not to say when this will be ready.
Best regards,
Aram Verwoest
Audio Ease support
It does this for me too. Some projects are fine and others will crash. Very strange.Mr Clifford wrote: I have been trying to troubleshoot to work out exactly which circumstances cause the crash on save. It's not happening on every project. I opened up a project this afternoon with several Altiverb instances, including Audio track inserts as well as Aux channel busses, and it all worked fine and saved perfectly.
Thanks for that. I appreciate how quick, upfront & honest they've been about it. If only Altiverb wasn't my #1 go to plug-in that I absolutely can't do without! (that and MW EQ, of course)The only two solutions are: 1) wait for our fix, 2) revert to an earlier macOS (10.12 or lower). Both options are unfortunately not very pleasant, sorry.
Thank you... saved me from pain; much appreciated.rk21 wrote:Audio Ease confirms it's a bug:
Hi,
Thanks.
Best regards,
Aram Verwoest
Audio Ease support
I understand that the latest version of CCC 5 can do this and install a Recovery partition. Neat trick if it works but I understand that they finally got it right.HCMarkus wrote: Note that if the issue is, in fact, the disc formatting, I understand one can install Hi Sierra on a spinner then clone it to a boot SSD to avoid the new Apple formatting being applied.
