Recording sound from internet to Ultralite
Finland Blue
Post by Finland Blue »
I have a MOTU Ultralite, Windows 7, and Sound Forge.
I am trying to record sound from internet into Sound Forge, but cannot get it to detect the sound and record it.
Can anyone advise settings I should check?
HotShot
Re: Recording sound from internet to Ultralite
Post by HotShot »
Hi Finland Blue:
Here's one setup that will allow you to record audio streams from the Internet:
- Setup Windows default playback device as MOTU Analog 1/2 and select "Properties" for MOTU Analog 1/2 and make sure 44.1 KHz is selected under sample rates of the "supported formats" tab.
- In the MOTU Audio Console, make sure Return Assign is Analog 1/2 and the sample rate is 44.1.
- In Soundforge, select Stereo ASIO Return as the input device, and you will have to enable input monitoring in Soundforge to hear the source you are recording.
Hope this helps.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
Finland Blue
Hello Hotshot - sorry, I missed your reply earlier. Thanks for the suggestion. I got the internet stream to record ok now this way, but the level ks so small, just a thin line of audio graphic in soundforge. Ultralite seems to be set max in the mixing section. How can i get the level up?
nutsobad
Post by nutsobad »
Hi,
thanks for this 8 years later... now can you tell me how can I record the sound played from media player with my voice (by the microphone plugged on in 1) ?
exemple : when I want to quickly record a freestyle or repetition ..
terrybritton
Post by terrybritton »
nutsobad wrote:Hi,
These days, for Windows users at least, we have the donationware virtual mixer available here (free to use, but honor-bound to donate something).
https://www.vb-audio.com/Voicemeeter/index.htm
and for more options:
https://www.vb-audio.com/Voicemeeter/banana.htm
If you have a quality USB interface, selecting that as the A1 output device uses its buffer settings for low latency use.
Go to my YouTube channel (bottom of my sig) to find lots of Voicemeeter tutorials I've made over the last couple years that might help you. Start simple.
Terry
MOTU 828 mk3 hybrid
