Click enabled on all saved projects
primeevolutionary
Post by primeevolutionary »
This wasn't happening yesterday. Today, every saved project I open, opens with the Click (little metronome symbol) enabled.
It's easy to turn off, but, why would this be happening?
Macmini9,1 (M1, 2020) 16 GB RAM
MacBookPro15,1 2.6 GHz 6-Core (Intel, 2018) 16 GB RAM
OS X 14.7
DP11.32
2 896 mk3 192 kHz Hybrid FW • USB2
Stage-B16
2 828 mk1s
MTPAV USB
FMiguelez
Re: Click enabled on all saved projects
Post by FMiguelez »
That's the way DP's initial template is setup, apparently.
You can change it there and save it (I suppose it's the one called "New"), or better yet, create your own template and always start from there, so you always see your initial DP project the way you like it.
A good template is very important!
primeevolutionary
Thanks, FM, but, this is happening on saved projects, not new ones.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
