This wasn't happening yesterday. Today, every saved project I open, opens with the Click (little metronome symbol) enabled.
It's easy to turn off, but, why would this be happening?
Click enabled on all saved projects
- primeevolutionary
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
- FMiguelez
Re: Click enabled on all saved projects
That's the way DP's initial template is setup, apparently.
You can change it there and save it (I suppose it's the one called "New"), or better yet, create your own template and always start from there, so you always see your initial DP project the way you like it.
A good template is very important!
- primeevolutionary
Thanks, FM, but, this is happening on saved projects, not new ones.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
