WHAT EXTERNAL HARDDRIVES DO YOU USE?
anyone tell me about good bad experiences?
I have read some bad reviews. I was thinking about buying something from macsales.com anyone/
Powerbook 1.67Ghz 1.5GB RAM, a few waves plugs, Digital Performer 4.61, Logic Pro 7.1.1, Kontakt 1.5, Garritan Personal Orchestra, Reason 3.X, MOTU 828 mkII
- giles117
Maxtor or WD inside a Firewire Case. I had a Lacie and it crapped out on me so I pulled the drive and place it inside a $30 Firewire/USB 2.0 Case and all has been well.
Here is the Apple Profile View of the device....Firewire Mode.....
And the USB Profile
(1394 ATAPI,Rev 1.00):
Manufacturer: PL3507 Combo Device
Model: 0x1
GUID: 0x50770E50929094
Maximum Speed: Up to 400 Mb/sec
Connection Speed: Up to 400 Mb/sec
Sub-units:
(1394 ATAPI,Rev 1.00) Unit:
Unit Software Version: 0x10483
Unit Spec ID: 0x609E
Firmware Revision: 0x12804
Product Revision Level:
Sub-units:
(1394 ATAPI,Rev 1.00) SBP-LUN:
Capacity: 115.04 GB
Removable Media: Yes
BSD Name: disk7
OS9 Drivers: Yes
S.M.A.R.T. status: Not Supported
Volumes:
Audio B:Up Drive:
Capacity: 114.91 GB
Available: 31.9 GB
Writable: Yes
File System: Journaled HFS+
BSD Name: disk7s10
Mount Point: /Volumes/Audio B:Up Drive
And the USB Profile
ATAPI-6 Bridge Controller:
Capacity: 115.04 GB
Detachable Drive: Yes
BSD Name: disk7
Version: 0.01
Bus Power (mA): 500
Speed: Up to 480 Mb/sec
Manufacturer: Prolific Tech. Inc.
OS9 Drivers: Yes
Product ID: 0x3507
Serial Number: 3505090C209094
Vendor ID: 0x067b
Volumes:
Audio B:Up Drive:
Capacity: 114.91 GB
Available: 31.9 GB
Writable: Yes
BSD Name: disk7s10
DP 6.02
Euphonix MC Control
Euphonix MC Control
- KarlSutton
- giles117
Kano is Quite expensive I must say. $569.00 Just for a Case.....qo wrote:Check my Gear link below, which has links to the various components of the eSATA setup I use. It's been a joy to work with since it just works, is infinitely expandable by hot-swapping drives, and can't be overloaded (as far as I can tell so far).
DP 6.02
Euphonix MC Control
Euphonix MC Control
- qo
There's probably less expensive, but I didn't see a couple hundred here or there as being worth the effort to search any further than I did. The case allows for hot-swapping drives and for infinite expansion (just pop an empty SATA drive in). Too, it includes 4 SATA connectors (dedicated SATA to each drive), so the bandwidth to the case is 4xSATA. Plus, e.g. status lights, power supply for 4 drives, and being brushed aluminum, it looks like a small G5giles117 wrote:Kano is Quite expensive I must say. $569.00 Just for a Case.....qo wrote:Check my Gear link below, which has links to the various components of the eSATA setup I use. It's been a joy to work with since it just works, is infinitely expandable by hot-swapping drives, and can't be overloaded (as far as I can tell so far).
- giles117
Still seems high for a case that I have to spend another $400 to $500 filling up with drives.qo wrote:
I stuffed 4 additional drives in my G5. I f I need a removeable, firewire is adequate. I have 2 of my internals raided so if I need speed I transfer the file.....
Of course that is what works for me.
I prefer one of these solutions similar to what you have for only 170 for the case. or even an 8 Bay Case for only 270.00 Looks mean nothing in a machine room. And functionality isnt changed. Cant see drive lights in a machine room, but you sure can hear 4 drives spinning in a control room.
Also SATA only supports one device per port/connection so it is no big spec that there are sep connectors for each drive. All eSata Solutions provide that cuz the spec demands it.
So in the end I am speaking of a similar solution that runs 400 less than the Kano. Even if it doesnt look like a mini G5.
BTW just grabbed 4 250GB SATA Drives for 80 a pc. so for 530.00 One could have 1TB of eSATA in the case for 40 bucks less than the Kano Case alone. Then I can spend that additional 400 on my wife (Vacation/Spa, etcc... = Great Loving
DP 6.02
Euphonix MC Control
Euphonix MC Control
