importing OMF or AAF trouble
Hi all trying to import OMF files & they are showing up but not playable x ed out...AAF will not even show up... Video editor is using an Avid setup any thoughts also frame rate is 23.976 thanks for any help Cheers Gary
Re: importing OMF or AAF trouble
I wonder if he has some kind of an option set in his export. Are the files coming in as wav or aiff or ??? I'd try re-exporting an audio file (or all of them if you have a batch convertor) to match your project. It could be a header thing. Also, before he sends you the file, I'd also zip it/them (and the AFF) before copying to another disc.
thanks I appreciate the help !!! what are you using for a batch converter ???
Haven't had to worry about it own a long time, but I used Audio Finder. The page says it still does batch processing but I couldn't see the feature in the current version. I', sure it's there somewhere and I think they have a free trial version.
Many posts about this. I have had problems for years with trying to import AAF or OMF files in DP. The file starts to open and then it crashes. I see the tracks but it never gets past that.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Been a while since I tried it, but what worked for me in the past was importing the OMF into ProTools, and then exporting from PT. For whatever reason DP could open OMFs from PT, but not FC.
- Mark Walmsley
As I've posted re Premiere OMF imports to DP...
1. Don't have the audio embedded (it should be in a separate folder to the OMF)
2. Open your DP template
3. Drag the OMF onto the chunks window (wait a minute)
4. Drag all audio from the Final cut audio folder into the DP audio folder and
5. Wait a few moments for all the waveforms to draw
6. Voila!
Optional 7. I copy the audio from the OMF chunk to a clipping and then drag it back into my template chunk with buses already laid out
6. Voila!
Mac-Pro 8 core 2010, OSX 10.9.5, Motu DP 8.07, Apollo firwire, TC Powercore Firewire. User since Performer on Macplus in 1988
Thanks Mark i just saw this post
