DP crash when duration resizing MIDI in Seq. Editor
https://www.youtube.com/watch?v=13BdlbB ... e=youtu.be
Macbook Pro 15" latest, 10.11.2, DP 9.01, 828mk3 hybrid, very minimal fresh install of everything. Anyone else notice this?
- ccjones87
Re: DP crash when duration resizing MIDI in Seq. Editor
I've had the same issue. Only solution I've found is to edit MIDI in the MIDI editor. I do prefer the sequence editor though...
DP 9.5 OSX 10.10.5 Late 2011 Apple iMac 3.4 GHz Intel Core i7, 32GB memory 1333MHz DDR3
Oddly, this stopped happening. It just appeared in a new project with a fresh install of 9.01 and I thought I just hadn't noticed it yet. It has not reoccured with several hours of editing. If it happens again I'll try to reproduce.
- Shooshie
Not happening here. Could have been a corrupt file. If you go back to the file you were using before, does it happen again?
Perhaps yeah. I can't even remember which file it was. I know it was a brand new file with the issue happening within a few minutes of using it. If it rears its head again I'll note any reproducible parameters.Shooshie wrote:Not happening here. Could have been a corrupt file. If you go back to the file you were using before, does it happen again?
I'm encountering this issue as well in DP9.01, using VEP to host my VIs. I would love a solution too!
